Re: Anchor light at the top of the mast is not always required for 26?
Posted: Mon May 31, 2021 7:35 pm
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=28356
Yes, but some have Wheatstone bridge circuitry (basically, a rectifier) that results in DC of the correct polarity through the actual LEDs regardless of the polarity of the incoming power. The LED replacement bulb in my anchor light has such circuitry.
Yup, my mast top anchor light had such a thing and defeated my DPDT toggle switch. I had to install actual diodes to overcome it.Tomfoolery wrote: ↑Tue Jun 01, 2021 5:14 amYes, but some have Wheatstone bridge circuitry (basically, a rectifier) that results in DC of the correct polarity through the actual LEDs regardless of the polarity of the incoming power. The LED replacement bulb in my anchor light has such circuitry.
Same here. It's a shortened stick light, so I just buried the diode inside the stick stub.Russ wrote: ↑Tue Jun 01, 2021 5:29 amYup, my mast top anchor light had such a thing and defeated my DPDT toggle switch. I had to install actual diodes to overcome it.Tomfoolery wrote: ↑Tue Jun 01, 2021 5:14 amYes, but some have Wheatstone bridge circuitry (basically, a rectifier) that results in DC of the correct polarity through the actual LEDs regardless of the polarity of the incoming power. The LED replacement bulb in my anchor light has such circuitry.
Oooooh, I like that custom mast cap. How did you make that? My fiberglass?? cap is getting pretty beat up.Tomfoolery wrote: ↑Tue Jun 01, 2021 5:49 am Same here. It's a shortened stick light, so I just buried the diode inside the stick stub.
Starboard from West Marine, which is just high-density polyethylene boards. Same stuff plastic milk jugs are made from, only thicker and with black pigmentation. And UV stabilized, since it's intended to be used outdoors. I made three sections, stacked with SS wood screws that were too long but cut shorter. Still too long, but they don't touch anything, so it's all good.Russ wrote: ↑Wed Jun 02, 2021 6:09 amOooooh, I like that custom mast cap. How did you make that? My fiberglass?? cap is getting pretty beat up.Tomfoolery wrote: ↑Tue Jun 01, 2021 5:49 am Same here. It's a shortened stick light, so I just buried the diode inside the stick stub.
Dang Tom, that's a piece of art. That really looks nice. Same for your wiring.
I've made lots of stuff with it. Works easier than wood. Might find it cheaper elsewhere.
