The second black boat? hmmmm Thanks for the heads up Mike. Now where might that boat be............??....I then made one for the second black boat....
Did she have it??
Mike InmonModerator wrote:Commercial product info deleted. Please refer to commercial website, or send PM to Dealer.
Those interested may please refer to page 1 of this thread for related info.
WE ABSOLUTELY ENCOURAGE DEALERS TO CONTRIBUTE to the forums AS INDIVIDUALS.
Answering sailing and performance questions, contributing expertise for modifications, recommendations of effective motors or props ... all are encouraged as member-to-member exchanges. We all appreciate hearing General Factory info on the Macgregor products too, but only when it is NON-SPECIFIC as to a Dealership.
Please refrain from announcing any product or service information SPECIFIC to ONE dealership. Thanks. ~fc
How did that work out?We have used the rotating mast ( masthead, taller,larger main with battens,self tacking jib etc ) in so many versions we can only repeat ourselves.
I took several pics of the Pearla Noir when it was in Friday Harbour including some close-ups of the self tacking jib track and other rigging. Problem is I am a zeekCurrie wrote:I'm also curious about the self-tacker and how it works. I get the general idea - I'd just like to see one mounted on a Mac. If it's a reality, can you post some pics? Thanks!
~Bob
Roger has made a number of the self tacking jib systems over the years, even on his own 65/70 Anthem. First thing we do when racing is disconnect it But, they are wonderful! I am certain Roger's next self-tacking jib will be perfect. This is the problem with all known (to me ) systems: Just numbers pulled out of my ear. The wind loads/forces on the jib pull the clew to the forestay/tack at 100 lbs. 10ft from clew to tack gives 80lbs forward and 25lbs inward. The forward 80 is what we sail with and the 25lbs will pull the clew inward a little more than we want it to be. There is a force pushing the sail outward but slightly reduced by the inward component of the forward force. If a track can be made to curve exactly to match the opossing undesirable inward force and desirable outward force and if friction is reduced to a big fat nothing, problem solved.Gazmn wrote:Hey Mike,
You mentioned a self tacking jib as one of your experiments.
I like that the mast 28 has it - Sailing from my keyboard, that is.
Any insight you can give would be appreciated...
