It's the voltage that counts. An incandescent lamp is basically a resistive load other than the inrush current and will work on either AC or DC if the voltage is correct. That means a 120VAC bulb won't work on 12VDC. The voltage ratings on AC equipment is normally RMS (root-mean-square) which is 30% less than the peak voltage so a 120VAC circuit has a peak voltage of 169 Volts but would provide the same power to a resistive load as would a 120VDC voltage.So is an incandescent light either AC or DC, or does it work on both?
Lighting Questions
- baldbaby2000
- baldbaby2000
Craig LaForce
fuses
Standard 1 1/4 long US fuses did not fit in the panel on my old 26D. Bill at Macgregor in 1990s supplied some slightly shorter ones that did fit. Still have one or 2 and they fit the identical looking fuse panel on my X. Never thot to ask Bill if these are Brit or Euro spec fuses or to suggest another source.
