broken mast
My Time
Location: Formerly "matt19020" Bensalem PA... 2007 Suzuki DF70..."My Time" -
Re: broken mast
Post by My Time »
I do not know why I saved this but I did ......someone from this board originally posted this link and I saved it. It may be what you are looking for.
Dwyer Aluminum Mast Company:
http://www.dwyermast.com/families.asp?c ... Name=Masts
Chispa
Re: broken mast
Post by Chispa »
Thank you to Dave and Matt. I will look into your suggestions. Thanks!
bwytodd
Re: broken mast
Post by bwytodd »
The factory does not have stock the masts for anything prior to the 26M any more, so your local dealer can only get you an M mast. Much of your hardware will not fit correctly, and it is significantly heavier. Blue Water Yachts is now the supplier for the original masts made with the factory tooling. We also can cut the sail feed slot and drill the rigging holes to match your original mast and ship it almost anywhere in the U.S. Call us at 206-282-4261 if you need one.
