Cola
- bastonjock
Hardcrab
For what it's worth, alunimum does exhibit a very, very slight magnetic attraction.
My proof:
I have a very sensitive gun powder reloading scale that incorporates a thin piece of aluminum mounted to a plastic balance poise.
Permanent magnets are base mounted on each side of this aluminum piece at the zero balance point.
The aluminum slug moving through the magnetic field gap will slow and stop the poise oscillations so as to quickly get a zeroed reading.
The scale can measure down to 1/20 of a grain.
(The perspective for this is 470 grains per ounce).
An aluminum can next to a compass?
No way.
My proof:
No way.
- RickJ
- Sailboat: MacGregor 19
This effect is actually due to currents induced in the metal as a result of it moving in the magnetic field. It's not because aluminium itself is "magnetic".Hardcrab wrote:The aluminum slug moving through the magnetic field gap will slow and stop the poise oscillations ...
The motion of the metal causes eddy currents to be induced in it, and these currents themselves generate a magnetic field that opposes the motion. It's the electromagnetic equivalent of friction (the energy is dissipated as heat in the metal).
The coke-can thing has to be some sleight of hand. Neat party trick though
Cheers, Rick
