That was my point exactly, but then it disappeared1. In any accident, even if your not at fault, people will look for the slightest reason for you to be culpable and not having your boat secured could be one issue, even if it had nothing to do with the accident.
You can do all of the defensive driving you wish, but things happen. It's naive to believe otherwise.. The question then is does it make sense to be proactive and use tie down straps, or believe your defensive driving will overcome all problems that will come your way.
And I do believe the example of the Mac bump is a good one. If we can overcome the friction of the boat to make it move forward, something unexpected can happen to make it go sideways. Even forceful enough to sever the bow strap and make the boat go backwards. Again, good luck to those who believe otherwise. This is not meant as sarcasm. I mean it, good luck.
