This is something I'm working on
http://www.youtube.com/watch?v=u3QNHpzy7io
http://www.youtube.com/watch?v=Cd34onRJzEc
.by Trouts Dream » Mon Jun 02, 2008 1:19 pm
My favorite sail in light winds is my asym spinnaker, with chute.
When I first installed a CDI furler and tried to take some rake out of my mast, I installed a 2nd set of hounds 8 inches higher on the mast. I left the lower hounds in place and added a second forestay.
The lines for my spinaker are left in place, with the sheets attached to the clew line at the bow. I ran a clew line along the port side (parallel to the furler line) and through a sheave at the bow. I use the D Dunne method of levering to make it easier to attach the furler and this leaves me an attachment point just aft of the forestay tang.
I will try to post pictures in the near future.
This allows me to fly my spinnaker as much as 8-10 ft off the deck or pull it tight enough to sail a beam reach. In the right wing I have been able to get about 10 degrees higher than beam using the spinaker. Most of the time I will use the spinaker alone, no main, and just sit back and look at the pretty colours against the sun and sky
