Good point. On our recent trip, I made it a point to divvy up the house loads between the two batteries, and it wasn't really a hassle, but yes... having just one big bank would certainly simplify things and extend battery life.Duane Dunn, Allegro wrote:The other thing you gain with the single bank, beside simplicity and cheaper components (link 10 vs 20, no combiner, no 1/both/2 switch, etc.) is longer life.
Say you normally pull 30 amps out of your house battery. This probably is about 1/3 of it's capacity. It will be able to tolerate this for a certain number of cycles. While you do this your starting battery sit's there with almost always a full charge contributing nothing to your daily needs.
I'm considering getting one of those nifty Engel refrigerators as a Christmas gift for my wife... she's been begging for refrigeration, but I've always told her that the power requirements are just too steep. Even with that low draw, my power consumption estimates show that about 2 days out is the best we could expect (depending on how much we motor). I might consider adding another 100ah battery, and if I do this, the two current batteries will get tied together as a single bank and moved up to the v-berth area, while the new one will go in the current battery location under the aft galley seat and be used as a starting and extra house battery.
Or, I instead might go for one of those little Honda or Yamaha generators, which I could run for a little while in the evenings to charge the batteries, presumably much quicker than my Honda 50's little 10 amp alternator. I currently have a big, noisy Coleman generator, which I could sell and get a smaller one that could be used both at home and on the boat.
--Mike
