Page 3 of 4
Re: Legend "The Edge" vs S-850 vs 26M
Posted: Tue Jan 18, 2011 8:44 am
by Highlander
Posted: Tue Jan 18, 2011 10:28 am
by arknoah
Let me get this straight? You were sailing and filming from the bowsprit?
That takes some serious guts!
Posted: Tue Jan 18, 2011 11:08 am
by mikelinmon
About the sailing ability, the Edge uses 50% more hp to get less speed! Mac has a rotating mast to get more pwer from its sails and a much lower drag hull. Now just how do i know that? Hull on the edge is a close copy of our old M-19. We changed it to the X for more sailing performance. We then changed it again to the M for even more. Hunter copied our powersailor idea, they just copied the first powersailor. Should have copied the X or even better the M. Same thing with the water ballasted boat, copies are not as clean as the original. By the way, has anyone seen a 2011 Edge, I don't think so. Maybe, I'm just saying. Last boat show we were showing a brand new 2011 and the Edge was an older "demo".
Mike Inmon (vested interest and all)
Posted: Tue Jan 18, 2011 11:46 am
by magnetic
The one I saw last week at the Boat Show looked pretty new; I used to have a :mac19: and believe me, this was not the same boat, or the same hull. The chine is different for a start, the belly and beam are far far wider, and the Edge appears to have a "hook" just in front of the wheel
Posted: Tue Jan 18, 2011 3:31 pm
by ROAD Soldier
Ok Highlander this is probably a "Moot" point but after viewing your awesome videos you posted here and in my email I see you have totally missed the mark. :o To be a sleeper you need to be covert in your mods. :idea: Yours are way to professional in appearance and lack a total discreetness that a true Redneck would use in order to make his fast boat look like a slug. :? In fact your mods make your boat look to much like a Porsche on water. 8) In your mods I saw no rough cut good old boy Wal-Mart Cutting Board styles, exposed PVC pipe with blue glue joints showing anywhere, or most importantly where is the duct tape :?: :wink: So as much as you may want me to be "Mute" about your total ineptness of proper demonstrating highly classified Redneck stealth skills in building a sleeper, I have to do my Redneck duty and insure that others on the site are not misinformed. :) Now feel free to keep sending my your latest videos so I can properly give you constructive criticism in staying abreast of the latest Redneck fads. :D
Posted: Tue Jan 18, 2011 8:47 pm
by Hamin' X
magnetic wrote:
Hamin' X wrote:The Mac will fit in a standard "Overseas Shipping Container"
- no it won't - I shipped mine from Dubai to Hong Kong, and you need a Hi-top container (and don't expect any guidance from the factory on how to go about getting it in)
Perhaps you should sue the factory for false advertising? I don't think that that will work though, as they manage to do just this very thing on a regular basis and many others have as well. :o Unless your :macm: is very different from the thousands of others, you might have done something wrong. :? Did you remove the springs and axles? Perhaps this would lower it enough for a standard container? Or, I could be all wet, as I have never shipped an :macm: , :macx: , or any other boat for that matter. Just going by the factory info and what I read here from Philip, José and others. :D
Posted: Tue Jan 18, 2011 9:39 pm
by Highlander
Well I guess our rednecks up here must be more affluent !! :D :D :D :P
Now I did try flying 4 headsails last yr but did not have enough cleats installed at the time to hold all the sheet lines so it was a major PITA cause I could not trim the sails properly & in a gust you only have to worry about easing your main, jib & genny as the stayil & storm jib are small enough not to worry about 8) :wink:
got the hardware now so watch out this spring :P
So as my rolls royce boat would be honking some other guy's ferrari boat !! :D :P :wink:
Guess with all that hot air down their ya will be putting your boat in the water early this Spring :P
:D :D :D
Posted: Tue Jan 18, 2011 11:49 pm
by magnetic
@Hamin
Axle off, mast crutch down, you still need a Hi-Top. Try it some time.
It's the same price as a regular container, unless you order the regular one first and then have to pay a restock charge for changing it. I think you'll find that new Mac's are shipped on sleds not their trailers
Posted: Wed Jan 19, 2011 6:15 am
by Divecoz
But Magnet isn't that just how they ship many of them here... coast to coast .....border to border ??I think there is even a picture to be had somewhere IIRC???? But maybe they do ship all the macs on sleds?? I'll give Bill @ Boats 4 Sale .....MY HERO : ) a call if I get the time..
magnetic wrote:@Hamin
Posted: Wed Jan 19, 2011 3:07 pm
by ROAD Soldier
Could you leave the axle on with a Hi-Top milvan? If you could and there is no added expense for a Hi-Top then I think the discussion stops there.
Posted: Wed Jan 19, 2011 7:28 pm
by Highlander
magnetic wrote:The one I saw last week at the Boat Show looked pretty new; I used to have a :mac19: and believe me, this was not the same boat, or the same hull. The chine is different for a start, the belly and beam are far far wider, and the Edge appears to have a "hook" just in front of the wheel
The Edge hull I believe in the pic's I was looking at from Andy's post & the one I seen @ the boat show has a flat bottom like the X with intrunded hard chines
The :mac19: hull has 17deg deadrise V-Hull with hard chines a completely differnt beast !
http://i78.photobucket.com/albums/j95/m ... 010027.jpg
http://i78.photobucket.com/albums/j95/m ... 010029.jpg
http://i78.photobucket.com/albums/j95/m ... 010023.jpg
Posted: Wed Jan 19, 2011 7:51 pm
by magnetic
for you, my friend, I think it probably does :|
Posted: Wed Jan 19, 2011 8:32 pm
I never heard of the S yachts until I started reading this thread. After checking out the company's web site, I think I may start saving for a 950 :evil:
Posted: Wed Jan 19, 2011 8:33 pm
by Highlander
now I found this very interesting swing keel set-up
http://www.steynor-keel.co.uk/index.php ... scription/
was wondering how mutch it would weigh now this could be inserted into an M or X I think leaving it extended down say 3"-4" for a nice center skeg would help in following see's & powering slow in windy days in marina's
Posted: Wed Jan 19, 2011 9:42 pm
by Hamin' X
Highlander wrote:now I found this very interesting swing keel set-up
Interesting concept!
Rich
