Aft Wanders Like Crazy on Mooring?
FAAbaddog
Location: Pensacola Beach, FL "FINS-UP" 2011 26M E-TEC 60
Re: Aft Wanders Like Crazy on Mooring?
Post by FAAbaddog »
All,
Installed my Starlite anchor riding sail last evening before the wind picked up with gusts to 30kts, it works!!! :)
Only about 20-30 degrees of swing in the back, just jibes back and forth. I plan to add some quick disconnects today when the wind dies down.
Thanks!
BADDOG :macm:
yukonbob
Post by yukonbob »
Anyone try a small sea anchor? Like one from a canoe or a kayak?
March
Post by March »
Attaching it to the aft is not a good idea. It may hold for a little while, but if the wind gets stronger, it will drag even so. We used one the first couple of seasons. The anchor rode got entangled around the depth sensor and pulled it out overnight--an expensive replacement. On a different occasion, the wind changed during the night and the aft rode got entangled with the main anchor rode, weakening its holding power. The boat drifted. It would have been more securely anchored with only the main one.
The tail sail seems like a much better option. The "bridle" method is also pretty effective
Trouts Dream
Post by Trouts Dream »
Just ordered my Starlite anchor riding sail ....I'm going to suggest they send a sales commision check to this site :)
Boblee
Post by Boblee »
mastreb wrote:Did you make your bridle? I'm googling for info and find a lot of people talking about them but nothing on where to find one or how to make one.
Just a truckie hitch etc (easy to undo) in the appropriate anchor line and another line tied back to the stern or winch and adjust either to suit, preferably in daylight.
Reason: Repaired Quote
Here is a post from way back in July of 2005. I hope this helps.
Report this postReply with quoteSailing at Anchor
by Jack O'Brien » Wed Jul 06, 2005 11:18 pm
Got to try the "bridle" solution last week anchored off Bimini. 5 to 10 kts breeze, 15 feet deep, single 9# danforth, 150 feet of rode with 16 ft of chain. Typical X sailing back and forth about 150 degrees.
Put a dock line on a snatch block, snatched it on the rode, ran dock line back to genoa gunwale block and then to winch. Hauled in the dockline until the snatch block was about 10 feet aft the bow cleat holding the rode. REALLY steadied the boat. Limited sailing on the anchor to 30 degrees max. MUCH better than the anchor riding sail.
Only reason I used the genoa block rather than going straight to the winch was we had the dodger in place and it was in the way.
baldbaby2000
Post by baldbaby2000 »
Is there any reason not to use the snatch block method? It seems so easy.
Hamin' X
Post by Hamin' X »
I have used these "Knot Eliminators" for years on the trail to picket horses and mules:
I plan to use one to make a bridle for my :macx: While on the hook.
baldbaby2000
Hamin' X wrote:I have used these "Knot Eliminators" for years on the trail to picket horses and mules:
I like it. Fro 10 bucks it's worth a try: http://www.nrsworld.com/iStar.asp?a=29
I'll also probably try the snatch block idea or a carabiner. Seems like that would be easier to undo quickly if one had to weigh anchor.
Boblee
Post by Boblee »
Thats a beauty Rich shouldn't slip.
Rich,
I'm just inquiring, is that plastic? Is it strong enough to put up with some sudden, strong wind?
yukonbob
Post by yukonbob »
You could also use a figure 8 for rock climbing ($15) exact same idea but high strength aluminum used for rock climbing/absailing.
Hamin' X
Post by Hamin' X »
Thr Knot Eleminator is made from HS Aluminum and shrugs off a 1500 Lb. mule that tries his best to bust it.
Hamin' X wrote:Thr Knot Eleminator is made from HS Aluminum and shrugs off a 1500 Lb. mule that tries his best to bust it.
Her. Mules are all female. :wink:
Matt
Hamin' X
Post by Hamin' X »
Sorry Matt, You are wrong.
