One more thought, instead of buying a new Mast Base Plate from BWY why not have one made by a local machine shop that has taller side mounting brackets so the bolt hole can be placed an inch or so higher on the mast.Fxwg80hd wrote:Tony - Just looking at the picture again, but have you thought about having a sleeve welded to the bottom of the mast so you can use the original bolt hole location again? Would save you having to cut the mast, raise the forestay, and raise or adjust the side stays.
If welding will weaken the mast, then maybe have a sleeve made that can be riveted or bolted on and still allow you to use the original base plate bolt hole location on the mast.
Chris
