I just changed my 1997 MacX steering to a Uflex Rotor with a 9 ft. cable.
This works excellent for the exit cable forward from the previous aft exit cables that were from 1995 to mid 1997.
Those 1997 models have changed location for the exit steering cables and should be noted in the forum.
Even the Aluminum steering arm was changed.
Had a Talk with BW and they are not sure when changes were made.
Rudders, swing arms, rudder brackets to stainless...lot of changes.
Seapup wrote:My 2 cents...
Rather than buy a quick disconnect go the opposite direction and buy the correct drag link for your motor. Connect the outboard the way its manufacture designed it to be used, permanent & solid to the steering cable though the tilt tube with a drag link. No more motor flop due to the mac linkage leverage or play in the steering system from steering a heavy motor through all the mac levers and joints.
Moving the steering cable to where its intended is a simple change on the X, not sure about the M.
