Re: 26m Docking advice and suggested reference videos?
Posted: Mon Jun 04, 2018 9:39 am
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=26818
Just don't get too dependent on crew to slow the boat to a stop; best to stop it dead with the engine, as you're the only person you can trust to do his job. That's why I sail and dock single-handed, no matter how much crew I have.MaritimeMenace wrote:The second time docking yesterday was A LOT better. This time I had a friend on the bow with a docking pole slow me down that last 'little bit'.
You might want to think of ways to have permanent dock lines, already on the cleat. Many folks, me included with a different boat, have some sort of stanchion to hold the dock line at the ready so you can just grab it and put the eye splice right onto a winch drum or cleat. On a keel boat I used to have, I had a spring line dedicated to that one job - flop it onto the winch drum and motor against it gently (if needed) while I put the bow and stern lines on, also with eye splices that could be flopped over their respective cleats, to be augmented and/or cleaned up one at a time once the boat is secure.MaritimeMenace wrote:From the cockpit I 'lassoed' the end-finger cleat while my friend tied off the front of the boat.
Believe me, I understand that. But if the finger pier is that short, you might seriously want to reconsider. Everything is everything when the weather is nice and the water is calm, but try coming in when the wind pipes up and you're getting knocked around by chop and the wind is blowing you away from your dock. And you're alone. Been there many times, and that's when dock lines at the ready, perhaps hanging on pvc pipe 'hooks' for easy grabbing (but won't hurt your boat if your rigging grabs them), are heaven-sent. There's nothing like the feeling of getting two lines on the boat when you're barely able to get the boat into it's slip.MaritimeMenace wrote:I'm docking bow first, mostly because I want to have a nice lake view while I sit in the cockpit.
See above - no need to lasso if it's already on the cleat or piling, at the ready. At one marina long ago, I actually had a two-piece spring line, with a big ring spliced to the end of one half (cleated at the dock, and hanging on a hook), and the other end with a big heavy SS carabiner on the mid-ship cleat, so I could just snap it onto the ring, then motor forward against it. I eventually found that it was just as effective to use a short stern line, already on the piling and hanging on a hook within reach (wooden piling), and just flop it over the stern cleat, and that's pretty much what I do now with theMaritimeMenace wrote:Lassoing the first cleat with the spring line is difficult, because my particular dock fingers are so damn short. They barely make it to the cockpit when the boat is in bow first.
This devise (not necessarily from BWY) has been discussed before. I don’t remember exactly what the overall consensus was, but my concerns are how it will be used. “A chain is only as strong as its weakest link” may apply here.MaritimeMenace wrote:for a Mid-Ship Cleat, I saw this Sliding Track Cleat on the BWY site.
I'm not sure if it'll interfere with my Jib Cars though. I'll shoot a question off to Cheryl!
http://shop.bwyachts.com/product-p/4206-1v4.htm
Tomfoolery wrote:You might want to think of ways to have permanent dock lines, already on the cleat.
Just wondering; do you have any chain on the anchor? I have thirty feet of chain before the rode.when I know I'm going to dock I use my anchor rode and tie it to the bow and run the line (out side of stays) back to the cock pit and tie it there (anywhere just so I can grab it)
A anchor without chain is just a not overly heavy weight really, I run 12 feet of 5/16" and 12 feet of 1/4" chain, after dragging last time out in the middle of the night I added the 5/16" chain to get a better pull angle.NiceAft wrote:Just wondering; do you have any chain on the anchor? I have thirty feet of chain before the rode.when I know I'm going to dock I use my anchor rode and tie it to the bow and run the line (out side of stays) back to the cock pit and tie it there (anywhere just so I can grab it)
I agree, but there is a reason for my inquiry.sailboatmike wrote:A anchor without chain is just a not overly heavy weight really, I run 12 feet of 5/16" and 12 feet of 1/4" chain, after dragging last time out in the middle of the night I added the 5/16" chain to get a better pull angle.NiceAft wrote:Just wondering; do you have any chain on the anchor? I have thirty feet of chain before the rode.when I know I'm going to dock I use my anchor rode and tie it to the bow and run the line (out side of stays) back to the cock pit and tie it there (anywhere just so I can grab it)
