Page 3 of 4
Re: Venture 222 running rigging help
Posted: Sat Jun 19, 2021 11:58 am
by Be Free
I think I remember you not being able to pull the main high enough to get all the wrinkles out of it. It looks like your main halyard is attached to the shackle with a bowline. Switching to a halyard hitch may be the missing ingredient.
https://www.animatedknots.com/halyard-hitch-knot
Posted: Sun Jun 20, 2021 5:12 pm
by GonePostal
Agh... This is a good news/bad news type deal. Im pretty sure Ive got MOST of it squared away without everyones help. Thanks!
It seems like the jib sheet/halyard is good to go tho I havent actually raised it yet.
Ive also got the mainsail halyard (look at me and my use of the proper lingo!) hooked up and going up & down. But... the &%@# mainsheet...
Im attaching even more pocs in the hopes yall can point me in the right direction.
First, Im not sure WHAT I should be attaching to the end of the boom
Posted: Sun Jun 20, 2021 5:13 pm
by GonePostal
And the "backstay"...???? Should this somewhere else??? I cant tell where. Also... I have absolutely NO other rigging lines cables nothing
Posted: Sun Jun 20, 2021 5:15 pm
by GonePostal
Posted: Sun Jun 20, 2021 5:17 pm
by GonePostal
And fwiw my stern chainplate is not 100% centered... The wadp spray can is in the middle.
Posted: Sun Jun 20, 2021 5:53 pm
by Jimmyt
GonePostal wrote: ↑Sun Jun 20, 2021 5:12 pm
Good news: I think you have it rigged correctly for what rigging you have. Your boom has been converted to mid-boom sheeting, and the main sheet rig connects from the mid-boom bail to the bow eye (u-bolt) in the cockpit wall.
Bad news: you need to buy a main sheet rig. You should probably replace your backstay. You should run a separate topping lift.
Note: the bad news isn't really bad, but you need more stuff to make it right and complete. You were wondering what to do with all of your extra money, right?
I haven't seen a combination backstay and topping lift before, but it appears one of the previous owners made some changes.
My concern is how the topping lift is attached to the backstay. The backstay should be a continuous wire rope from the mast connection down to the backstay adjuster. In fact, I'm not sure I trust the backstay after it's been DIY'd like that. I would suggest getting in touch with
http://shop.bwyachts.com/category-s/291.htm, and see if you can get a real backstay and get them to explain the correct topping lift for that boat. Otherwise, you can run a separate topping lift of your own design. The backstay is critical. The topping lift is a convenience.
Posted: Mon Jun 21, 2021 5:51 am
by Be Free
After seeing both attachment points together I'm pretty sure Jimmy is right about the main sheet. The PO (previous owner) seems to have made several modifications to the boat. Moving the main sheet attachment point from the end of the boom to mid-boom reduces the forces seen by the main sheet. I am becoming more convinced that the thing on your backstay is your missing main sheet.
The only time the backstay should see any significant forces is when you are running with the wind behind you. In fact, for better performance it is common to loosen the back stay when you are not running. It is obvious that the boat had an adjustable backstay at one time but the adjusting part of it has gone AWOL.
This is what the adjustable backstay looks like on my
. Notice that it is only 3:1. That is more than enough to handle anything the backstay should throw at you. Being able to loosen the backstay also makes it a lot easier to attach the forestay when you are raising the mast.
Posted: Mon Jun 21, 2021 5:59 am
by Tomfoolery
Be Free wrote: ↑Mon Jun 21, 2021 5:51 amMoving the main sheet attachment point from the end of the boom to mid-boom reduces the forces seen by the main sheet.
Uh . . . might want to rethink that statement.
Posted: Mon Jun 21, 2021 6:11 am
by Be Free
I'm open to education. I must be remembering incorrectly. Hit me with the math.
Posted: Mon Jun 21, 2021 6:14 am
by Jimmyt
That was my initial thought, too. But I looked at the backstay kit from bwyachts- and guess what it looks like...
http://shop.bwyachts.com/product-p/3441-1v0.htm
Posted: Mon Jun 21, 2021 6:15 am
by Jimmyt
Tomfoolery wrote: ↑Mon Jun 21, 2021 5:59 am
Slow ball, right in the strike zone.
Posted: Mon Jun 21, 2021 6:16 am
by Be Free
Never mind. I just did a quick calculation on my napkin and you are correct. There are other advantages to a mid-boom connection but reducing forces on the main sheet is not one of them.
Posted: Mon Jun 21, 2021 6:18 am
by Be Free
Jimmyt wrote: ↑Mon Jun 21, 2021 6:14 am
That is one beefy backstay adjuster.
Posted: Mon Jun 21, 2021 6:21 am
by Jimmyt
Be Free wrote: ↑Mon Jun 21, 2021 6:18 am
Looks like they had some extra main sheet rigs laying around and figured this was a good way to move them out...
Posted: Mon Jun 21, 2021 6:27 am
by Jimmyt
Be Free wrote: ↑Mon Jun 21, 2021 6:16 am
Tom has a pretty large wheelhouse, and this stuff is smack in the middle. He's graded my work a time or two, and I always appreciate it. He never gives a wire brushing, just a correction.
And, I generally require a lot of them.
