Gas Tanks Redo
Be Free
Re: Gas Tanks Redo
Post by Be Free »
NiceAft wrote: Wed Dec 15, 2021 3:51 pm
Be Free wrote: Wed Dec 15, 2021 3:26 pm Nice Aft. If you do get the wet slip don't forget to check that they will allow you to refill your tanks from a portable tank. Some marinas frown on the practice.
I have not kept Nice Aft in a slip for several years now.
Life is 👍
Nice Aft,
Sorry, I lost track of who was speaking. It was OverEasy who was thinking of a rolling tank at a wet slip.
Congratulations on your wife's recovery. My wife was diagnosed in 2018. They caught it very early before it had spread at all. She's had a clean bill of health for almost two years now!
Re: Gas Tanks Redo
OverEasy wrote: Wed Dec 15, 2021 3:01 pm Hi Russ!
I like your portable rolling gas’s tank idea!!!
Marinas tend to charge a premium for dock fueling.
Sometimes as much as $1.50 a gallon over the same non-ethanol fuel available inland.😳
I’m not against the convenience of a fueling doc or acknowledgment that there are additional facility cost burdens for on dock refueling.
It’s just hard paying that much more when I grew up making the eagle scream before letting go of it….🙄
If we were to be able to get a seasonal slip it would be something we’d consider, if we could place a large enough locker at the slip to hold the roll-about tank after refueling the boat tanks.
We’d also have to make some sort of a ramp to get the roll-about tank into/out-of our van.
(It is a very very very bad idea to refuel a portable tank in/on a motor vehicle as it will develop a serious static charge during refueling!)💥
(Seen it happen…..not pleasant……)
Some similar roll-about tanks I’ve seen are gravity feed discharge, some have liquid hand pumps and others have a small 12VDC electric fuel pump. (Given the summer sun down here one could also just close the vent allowing the tank vapor pressure to increase…😜)
Great suggestion!
Best Regards,
Over Easy
As Ray mentioned, some marinas do not allow fueling from the dock. If we use up the 24 gallons, I pay the premium to fill from the gas dock. It supports the marina and part of the boat tax.
I first saw the rolling tanks at a marina that had small boat rentals. They used them to refuel the little boats.
However, they also have weight issues and are probably difficult to handle without a proper ramp from your vehicle.
Re: Gas Tanks Redo
Hi Russ
I’m not sure about me, but I bet the 150+lbs would have nothing on you! :D :D
Best Regards
Over Easy
Re: Gas Tanks Redo
Image :o :D
Re: Gas Tanks Redo
Be Free wrote: Thu Dec 16, 2021 4:43 am
Life is 👍
Nice Aft,
Thank you, and congratulations on that good number..
Now we return to the "Gas Tanks Redo" thread :)
Re: Gas Tanks Redo
Congratulations for both of you and your spouses ,👍👍🍾🎉🎊
You have a lot to be thankful for with each day!!
Best Regards
Over Easy 😎😎🐩🐈
