Is this the Brittany Spears guy I keep hearing about?Catigale wrote: Spear type 'spears' the clew ring (name comes from the technique originating in Brittany IIRC) and the clip type attaches to the sheet. I like the clip type, personally.
spinnakers again: Assymetric or symmetric
Bill at BOATS 4 SAIL
- Sailboat: MacGregor 26D
- Duane Dunn, Allegro
Furling a 150 genoa down to a jib size will never match the performance of a jib itself. Adding a luff pad will help take out some of the extra fullness in the genoa and can make it's shape closer to acceptable. Moving the cars to the cabin top tracks may also help, but the shape will never be as good.
If you find you are sailing often with the genoa furled, you would be better off with a jib to start with.
I much prefer the spike on the outer end of my whisker pole. Usually the sail is flying outboard of the lifelines when you are setting up the pole. With the spike you don't have to get the sail back in close enough to clip the end on.
I also prefer the spike for it's self releasing feature. If you get a big puff or for any reason need to let the sheets loose you can do so and the sail will self release from the end of the whisker pole. The pole simply drops to the lifelines.
Maybe the spike is why I have never damaged my whisker pole, although I suspect a back winded sail would be the most common way to bend a pole.
Stephen,
Most of "our vintage" Macs came with jib, Genny as an optional addition ... did you get only the Genoa?
If you had a hank-on jib somewhere in the bilge, the sailmakers charge about $5/ft. to add the #6 luff tape. Otherwise, you might find a used jib already "taped" in the surplus inventory at Minney's Yacht Surplus in Tinseltown (click Headsails to 25').
I've ordered from them before and they are good to work with. When I didn't like the fit of a used mylar sail from them, they took it back for full refund w/no questions -- my only cost was 2-way shipping. I trust their rating system for sail condition. Fact is, the SoCal guys say it's a great place to browse on a Saturday afternoon ... maybe on your next trip to SoCal.
That happened to me as well but I was using a boat hook extended out to 13ft with a paint roller cut off to an L shape that screws on the end & has a mast connection on the other end I got the mod of this site I repaired the boat hook now use it for my smaller jib stay sail 8ft foot & bought a heaver wisker pole to use on the genny when I fly my head sails wing on wing
With genny you can sail harder heaver sail 1.50oz
spinnaker 3/4 oz this one for the mac19 is about 200sq ft. My custom made spin is between 300-350 sq ft for my
spinnaker cloth my
I may need some beach whales for rail meat Sh-t I could be in trouble now
I know theirs no hope for me ? but I'm happy
