All good advice, especially that the combiner might not be able to serve a weak battery.... WE do not have a perKo switch.
Following the red cable from the engine under the aft to the 1st battery by the galley (99 mac)
we find no switches on the walls nor in the compartment ( under the seat).
From that battery#1 we follow red cable fwd to the dinette ... compartment where battery#2 is.
No perco switch.
There is a 1 inch by 2 inch black box ... with wire going in and out of it.
There are wires that attach to the battery. LOts that attach to one side.
(they have plastic tubes associated with them I think may contain fuses) ...
OTOH, this is a Costco battery, still under warranty. Still . . .
- Colleen describes both batteries are connected by heavy red cable (parallel).
- Also that the Start battery never failed.
- Also that the fuse panel service first dimmed, then went dead.
- If the batteries are cabled together, why doesn't the Starter battery serve the fuse panel?
- Also, if the batteries are cabled together, there's no reason to have a combiner.
Chuck or Colleen,
Seems that there's an 'info disconnect' in this story. If the two batteries are connected with a heavy cable, then the start battery "should" be serving the switch panel. Also, there's no reason for a combiner if the batteries are hard-wired together. Conversely, if the batteries are isolated, then the red cable must be interrupted by a switch ... at minimum, by the combiner. This is the only way to isolate the fuse panel from the Starting battery.
Need more info. Meanwhile, I also have a West Marine combiner-50, and I have the PDF of installation directions. I'll try to find a website for your download ... or else, send me a PM with your email addy (not in a post).
