may I suggest ye sailors rent a John Wayne cowboy movie. John Can throw a lasso.
Use slow motion to perfect the technique..
docking manners
Are you renting a slip? I leave the docklines on the slip and fender on the dock. That way I just need a boat pole to grab the dock lines upon approach.OverEasy wrote: ↑Thu Feb 25, 2021 9:00 pm
A technique that I’m working on is using an extendable paint pole that utilizes button detects that securely allows for both push and pull as a boat hook and dock line loop holder. The dock line loop is slipped under a pair of rubber bands like was described earlier in the thread. The line is pre run from the cockpit up through the bow cleat and back the cockpit where the loop is slipped under the rubber bands of the pole end.
Approaching the dock the pole is extended, the loop snagged on the cleat and slips out from under the rubber bands. As the line is hauled in and the boat moves back to align the cleat and bow and tied off in the cockpit. The engine thrust is then angled to push the stern to the dock. The process is repeated for the stern line. The engine is then shut down. This avoids any leaps or unattended running motors/vessels. It takes a little space and planning. But it works in winds, waves and currents.
Same here, but I don't use a boat hook to get it. The coaming is so low, I just reach over and grab the stern line that's laying on the floating dock, which I leave right at the edge for ease of retrieval.
