Back in 1982-1985 I built a Wind powered Generator and it worked excellent in the Trade Winds of the Carribean.
Those winds are usually 12-15 knots every day and would power all your elect. needs .
I didn't have voltage control back then(Reastrate voltage control) and had to shut down the 6 ft. redwood blade as it produced far more amps than needed to power refig. and other 12 volt items.
Back in the states it was usless because it only generated 1-2 amps in 7 knots of wind.
I have looked at current wind generators and they put out as much amps as I had up to 12 knots but mine went much higher at 12-15 amps in 15 knots of wind, but with a 6 ft. blade and noisy.
The chart you stated is probably close to what I have experanced but thats avarage 24 hrs. In FL. in late Spring to fall that 8 mph would be only 6-8 hrs a day avarage in Florida West Coast.
I would never think of installing a wind generator unless you are in a area that poduces 10 knots 12 hrs a day.
Even the new ones make noise that distract you compared to Silent Solar.
I would sugest to spend the money for the smallest rack with the most amps and warrenty for Solar.
Your higher gauge wireing and the controller is well worth the price for a travler spending over 2 weeks at a time and often.
How do you control Voltage and Amps from your Gen-set?
PS: On a 26 Mac.S were outboard only has a 5 amp rateing , a small windgenerator may come in handy motoring against a head wind up to 30 degrees off Port or Starboard as going 5.5 knots and apperant wind is 6 knots than you have around 11 knots that can be useful or even stronger headwinds of 12 knots you have 18 knots of wind that can produse 10 amps or more per hr.
Sumner wrote:Now look at....Crikey wrote:...Do you think you could easily achieve 100% if you added a small wind generator, without too much additional daily effort? Ross
...the above chart that plots the wattage for one of the more popular wind generators that is in the $600-$800 range depending on who you buy it from. At 8 knots, more than 8 mph, it is putting out 28 watts and even at 12 kn it is only putting out 62 watts.
Now you might argue that if it is putting out 28 watts 24 hours a day vs. maybe a solar panel only putting out say 80% of it's advertised wattage for about 6 hours a day that it would be equal to about a 100 watt panel. That would probably be true, but now we are counting on the wind staying with the average, but the average is just that, some days it is higher and some days it is lower.
If you had a big battery bank, and low energy needs you might be fine with solar and wind, especially if you over-sized the whole system. But on a boat the size of a Mac that is going to be hard to do. Also remember they recommend that wind generators be installed at 20-30 foot heights and that isn't practical on a boat.
At some point we might add wind on the new boat as it is a lot larger, but in the mean time we added a Honda 2000 generator and a good charger to handle any times the solar we are putting on can't keep up. I could of moved the ....
http://purplesagetradingpost.com/sumner ... de-13.html
...gen-set from the Mac over, but we want to keep that boat complete so that it is ready for use any time we might want to use it. The gen-set that I made is louder than the Honda, but not so much from the exhaust as I made a second muffler for it. The main noise is vibration from it running. We didn't want a Honda on the Mac as there is no good place to store it and the gen-set is always in place ready to go whenever needed. On the new boat, an Endeavour, there is a convenient place below to store it and hopefully with over twice the solar we won't have to pull it out much. We also got it to use off the boat for some other needs.
If we do add a wind generator it will probably be a commercial one vs. one I try and make. The one I quoted above also comes with a MPPT charger and they cost a couple hundred. Add that to finding a good blade and other items and pretty soon you would be up into the same expense and still wouldn't of had the design time they have put into their product. At home I probably will try and design something for use there as we would like to add solar and wind to the house as the years go on. We probably will tie into the grid if we do that.
Meanwhile I'd try and put as much solar on as possible and then use the outboard or a gen-set to fill in when needed.
Good luck,
Sum
