Couple of things I've learned (many readers probably already know):
- Until the boat is moving well, a gust will push the boat over in excess of 45 deg heel very quickly. When new, this is pretty scary.
- With winds almost always over 15 knots, I don't need the Genoa that I have. I've since ordered a jib. Efficiency is not my issue, stability is. I can do almost everything wrong and still get up to over 6 knots and close to the max speed for the hull.
- It is impossible to fill the ballast tank in a swell. Water just runs in and out. Completely filling and verifying the ballast tanks is now part of my checklist before getting underway from the pier.
- Should have got lines aft mods from the start. I've since added, using the standard kit from byw. Also added the mid-reef point using kit from byw and taking main to local sail loft. For me, it's more than just a single-handed sailing solution. I was up on the deck adding the reef (before I added byw's mod), and we caught a gust. Heeled somewhere between 50 and 60 degrees: me hanging on to mast with my feet hanging over water. When I got back to cockpit, my buddy noted, "You looked a little scared up there."
- I see a lot of folks talking about motoring <6 kts with board down. I usually do that in the marina, but found coming in one time that there is a drawback. The large freeboard can catch a gust and push the boat over to 10-15 heel (sails down), and the change will turn the boat. So, I now consider wind (direction and speed) before lowering the dagger board. It's actually a better solution if you have the room to slide-slip.
- I really wish I had a rudder-angle-indicator. I may get an autopilot in the future, but I'm thinking of adding my own mod.
- Similar to the other comments in this thread, I often have to "tack" under motor power due to direction of the seas, and find the "sweet spot" in terms of speed. That sweet spot changes a little with wave height, wind, and wave period. I've found that I enjoy surfing the boat.
Again, reading this forum has been a tremendous help!
