Tomfoolery wrote:I too have a 3dB antenna on my mast. I also have a spare VHF radio (same model as the one that's wired below decks). And the same emergency backup antenna in the pic above. And a hand held VHF. And a cel phone.
For my type of sailing, I think I'm reasonably covered.
The PO's had an antenna on the stern somewhere, as witnessed by the coax that's clipped flush with the thru fitting on the near the rudder cleat and existing termination behind the radio, but I don't know why they had it. Possibly for canal use, with no mast. But my hand held does fine for that (locks and bridges), so I never worried about replacing it.
Formal Training
- dlandersson
Re: Formal Training
Nice topic...but are we getting way off topic?
raycarlson
Re: Formal Training
One radio is all that's needed other than a small handheld for convienence. Just run two separate antennas to the same radio, If your demisted (pretty farfetched) you can quickly plug in second antenna,
Re: Formal Training
Yup. Or keep one of those emergency deals handy for your 25 watt distress call.raycarlson wrote:One radio is all that's needed other than a small handheld for convienence. Just run two separate antennas to the same radio, If your demisted (pretty farfetched) you can quickly plug in second antenna,
Since most of us don't take our boats far offshore this should be sufficient.
- Wind Chime
Re: Formal Training
We have this Shakespeare emergency antenna.
Had the occasion to use it a few years ago when the connector for the mast head antenna went on the fritz.
It worked great. The suction cup held well over the weekend trip on the smooth area just forward of the mast. The line of sight was not as good as the masthead, but it did the job just fine.
25 watts with this lower antenna was much better than our 5 watt handheld, that was breaking signal.
RussMT wrote:Yup. Or keep one of those emergency deals handy for your 25 watt distress call.raycarlson wrote:One radio is all that's needed other than a small handheld for convienence. Just run two separate antennas to the same radio, If your demisted (pretty farfetched) you can quickly plug in second antenna,
Re: Formal Training
Wind Chime wrote:We have this Shakespeare emergency antenna.
Yup. I would imagine the raw power of 25 watts makes up for lack of altitude and gain. Handhelds work great, but do have range limitations. I have several for dinghy use and monitoring ch16 from the cockpit.
Re: Formal Training
We are getting off topic, but I could not resist adding my two cents worth into this.
We have two floating hand held radios for emergency. The most use we get out of them is when we go ashore. The admiral and I are then able to keep in touch when we go separate ways. They worked well at the Annapolis boat show in October.
Re: Formal Training
Not far off topic. Formal training would teach that it is illegal to operate a VHF from shore without a special permit.NiceAft wrote:We are getting off topic, but I could not resist adding my two cents worth into this.
The question is "Is operating a VHF on a floating dock considered on shore?"
- Hamin' X
Re: Formal Training
You do know that marine VHF frequencies are not allowed for point-to-point land use?
raycarlson
Re: Formal Training
FCC was gutted many years ago, they have next to zero enforcement staff on payroll. Just don't be rude or hog the channel and you have zero worries using your handheld anywhere.
Re: Formal Training
I never said I was unaware.RussMT wrote:Not far off topic. Formal training would teach that it is illegal to operate a VHF from shore without a special permit.NiceAft wrote:We are getting off topic, but I could not resist adding my two cents worth into this.
The conversation is limited to "Where are you", and " I will meet you in __ minutes", and we never use channel 16.
Re: Formal Training
NiceAft wrote:I never said I was unaware.RussMT wrote:Not far off topic. Formal training would teach that it is illegal to operate a VHF from shore without a special permit.NiceAft wrote:We are getting off topic, but I could not resist adding my two cents worth into this.
As mentioned above, enforcement is nil and next to impossible anyway. I've done it as well. Yes, on an obscure channel.
Out here.... we're lucky people know what ch 16 is for.
- Wind Chime
Re: Formal Training
Now, officially way off topic ...
We have a set of handheld Motorola FRS/GMRH radios for use on land. They work great, the same as VHF line of site just less watts than handheld VHF. (about 1w verses 5)
http://www.lenbrook.com/motorola/frs_2006.htm
Re: Formal Training
...and we use the standard Horizon models that have both Marine VHF and FRS capability so we are totally legal...but I wouldn't sweat a quick conversation on 16 either way.
- yukonbob
Re: Formal Training
I keep a similar set for hunting, skiing, hiking whatever. 1 or 5 watt depending on which call button you use to conserve power. 15km clear line of sight capability (most I've seen it work is 7Km) 1-2km in heavy areas. Even picks up the marine weather forecast. Got them 6-7 years ago for $80.Wind Chime wrote:Now, officially way off topic ...
The conversation is limited to "Where are you", and " I will meet you in __ minutes", and we never use channel 16.[/quote][/quote]
