Motor
Posted: Thu Jan 13, 2022 6:52 am
50hp
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=27389
Sheppie62 wrote: ↑Thu Jan 13, 2022 6:52 am The Yamaha 70 AND Suzuki 90 seem to be most common options. But I have no experience with or experience with these motors. Anybody want to add info to this? What does blue water yachts recommend now? I don’t think you could aggressively single ski with a 90, I’m thinking it would slow the boat down when skier turns. Maybe casual skiing? Realistic speed with normal load?
From the original thread.PopeyePete wrote: ↑Sun Sep 01, 2019 2:06 pm 1)What is the maximum horsepower I can put on a 2001 26 x?
2) What engine would be the best to achieve it?
3)What speed (with and without water ballast) can I expect to get?
4) would it have enough power to pull up a slalom skier?
What is the exact numerical safety factor in Rodger's design margin? Based on what?
Starscream wrote: ↑Mon Jan 17, 2022 4:58 pm That said, the first time a 26X has a structural failure due to a 90HP I'll sell the motor the next day. I just hope it isn't mine that pioneers the failure mode.
The above is a baseline point consideration.Typically a minimum competent responsible commercial consumer engineered design margin is 25% or more above recommendation before failure.
Motor thrust, and transom load trends, as a function of motor hp, were what I found interesting in the article. The impact of motor setback was also enlightening. These numbers are independent of transom/hull design (other than the impact of long shaft vs short shaft which is potentially a function of transom height/motor well design - if not using a transom mounting bracket of some sort).
OverEasy wrote: ↑Mon Jan 17, 2022 8:59 pm Hi VkMaynard
That is the point!
There is no publicly available design data or calculations issued for the Mac26X or Mac26M.
The manufacturer made a max engine size determination and recommendation. Just tossing on larger engines without consideration of the implications isn’t something any reputable qualified design engineer would do.
Just because someone “gets away” with something beyond the manufacturer’s recommendation doesn’t make it valid.
Designing in additional margin costs money, materials and time all of which increase product cost. Not something a manufacturer does lightly.
Rodger MacGregor was and is a competent designer and he had competent design engineering staff. They deliberately made the decision to limit the recommended horsepower to 50 hp for the Mac26X and 60 hp for the Mac26M.
They deliberately chose to limit their market window. It’s important to bear that in mind.
Transom thickness is only one aspect. Corner structure for load transfer to the forward structure is another. Hull thickness and internal supporting structure are among several others that have to be accounted for. Then there are also the loads imparted during land transit. A good pothole or two at speed can generate substantial stresses. Repeating impacting stresses (such as generated on poorly maintained concrete highways) are another consideration that affects not just the transom but also the hull and supporting structure.
Wave / hull / speed loading interactions are challenging design consideration aspects. The faster a vessel attempts to move through the water the higher the hull stresses. Wave pounding depends upon wave frequency and height and speed. The hull in the Mac26X is relatively thin as begets a trailerable motorsailer. Higher horse power allows for higher speeds which can increase hull stresses. This is why powerboats designed for higher speeds have substantially thicker hulls and more robust stiffening structures.
So if someone chooses to hang an engine substantially greater than the manufacture recommended they are doing so “at risk” and the engineering term for that is ‘pioneering’. They don’t have any design data to support their decision. They basically choose to do it because they want to and “hope to get away” with it.
It’s their boat and their choice to be “pioneers”.
The hope is that prudence in operation is used and they slow down in other than smooth calm conditions. Water is unforgiving to people and boats. When things go sideways there can be real consequences.
I’m glad that there haven’t been catastrophic failures or damages. That’s a good thing as no sane person wants anyone hurt.
But there is no definitive engineering basis to substantiate substantial horsepower increases above the manufacturer’s recommendations.
Your free to do with your boat as you see fit but realistically you are also responsible for those choices.
Best Regards
Over Easy![]()
DESIGN PROCESS
All of our design work was done within the company. We did rely on naval architects to help us with complex structural calculations. I’ve attached a drawing of our rather powerful computers and a giant 41" screen that enable us to create digital images of every single part on the boat. These computer images were sent to computer control milling machines that provided all of the cross-sections we needed to create the plugs. (Plugs were wooden and fiberglass mockups over which the fiberglass molds were laid.)
Computer design enabled us to hold remarkably tight tolerances, and easily experiment with alternative design ideas.
Based on what? Cost, more compact size, pull start?
