Page 4 of 7
Bolt rope to slug/slider conversion
Posted: Sun Dec 12, 2021 10:00 am
by Sheppie62
Re: Running lines to Cockpit and other ideas to make sailing easier
Posted: Sun Dec 12, 2021 10:18 am
Not my forte'.
BOAT may be one of the better persons for suggestions.
Posted: Sun Dec 12, 2021 12:44 pm
by BOAT
Posted: Sun Dec 12, 2021 7:22 pm
by Sheppie62
Boat, is your 26m mast like C-2 or C-3? I may need both sides cut to get clearance and not cut into mast to much. I think I better call Mastgate.com before I do anything drastic.
Posted: Mon Dec 13, 2021 10:24 am
by BOAT
I dunno
I think it's this one:
Can anyone help?
Posted: Mon Dec 13, 2021 11:58 am
by Sheppie62
Oop’s I actually opened up sail cover and looked into mast slot. It looks to be B-3 on the chart, the back wall on the slot is straight across so the one sided mast gate from BWY would work. Sorry for my confusion.
Posted: Mon Dec 13, 2021 4:33 pm
Sheppie,
If your mast is lowered; can you remove the cap and see straight on what the channel looks like? Then make a comparison.
I'd say ask BWY, but I don't think it's ethical to ask and purchase somewhere else
Mast type and gate construction
Posted: Mon Dec 13, 2021 7:03 pm
by Sheppie62
So I have located a sail shop that will install/ sew on the straps and slugs for $175. I will buy the mastgate from BWY (like BOAT suggested) and make sure it will work correctly with my mast before cutting the slot opening. And closing original lower slot opening of course. This is going to be SO MUCH!! Better
. Thanks everyone for the help! I will run lines to cockpit later, one step at a time.
Posted: Wed Dec 15, 2021 8:51 am
by Highlander
I made my own mast gate
Posted: Sat Dec 25, 2021 7:11 am
by Highlander
I forgot to post an end view of the mast gate, I conformed it to the shape of the mast notice it has a slight curve to it
Posted: Sat Dec 25, 2021 10:10 pm
by Sheppie62
Thanks Highlander, I have several pieces of aluminum to chose from to make the gate. I ended up buying a new sail instead of adding the slugs to the original sail
Posted: Tue Dec 28, 2021 4:30 pm
by Highlander
Sorry but I think u might have the wrong sail, so why not send it up to me for further inspection,
Just saying that's all
Posted: Thu Dec 30, 2021 5:56 pm
by Stickinthemud57
Sheppie62 wrote: ↑Sat Dec 25, 2021 10:10 pm
I have found that buying a new sail is pretty much the solution to any problem I might be having with my boat!
Closed old mast gate and made a new one up higher
Posted: Sun Jan 02, 2022 12:56 pm
by Sheppie62
Closed old mast slot and made a new one up higher. Next step is to make a mast gate, drill holes for bolts and install some stainless rivnuts in the mast. Think that may do it. Will I need any other modifications to make sail work? How does a loose foot vary from a bolt rope on the boom? Sail has a Cunningham (to pull sail tighter/ looser?). I’m not sure how that works, as sail bottom hook may come undone when tightening the Cunningham.
Posted: Mon Jan 03, 2022 1:20 pm
by Highlander
I just tapped two i think 10x24 or 10x32 thread's into the mast
