Buying a new Mac
- ALX357
Fuel line .... As Frank says, keep a new one in reserve, out of the elements. What would be the point of having two fuel lines out in the cockpit at the same time. ?
If you are quickly switching the fuel line while running,
the connection to the fuel tank is easier access than the connection at the motor. You would have to be reaching down to the base of the motor head while it was running and the boat moving ( maybe fast).
You still only need to disconnect and re-connect one fitting if you just switch the tank end of the hose from one tank to another under the seats in the cockpit.
The added fuel available in the fuel line gives you more time to complete the task and keep the engine running if the unexpected delays your re-connect to another full tank.
Blue Hull ... shows scratches, dock rubs, hazing and oxidation fade, and an irregular buffing from fenders rubbing the hull.
Traps sunlight heat, makes the boat interior hotter especially when closed. Not a problem in northern climes, but in FL, AL, GA, TN, SoCal, TX, LA, etc. all your stuff inside will be getting (more) baked. Electronics, rubber gaskets and seals, possibly cameras, flashlights, (BATTERIES), your porta-john's contents, the water tanks, so forth. More heat promotes faster mildew growth, ageing of plastic and rubber, and personal discomfort.
In spite of this, it is popular for its looks, to some owners.
The same people who buy black cars.
I prefer white cars, and white hulls.
- Bawgy
I went Blue hull Jib and Genoa (never used ) Kelly hanson spinaker and chute-scoop Etec 50 Wouldnt mind the extra power but this one is ok . It a real wet ride over 13 -14 kts with any chop. MAST RAISING KIT . I had will put in ac outlets . Two battery system with Perko , Bimini, canvas covers I love the boat for what it is . I raced a J109 so got spoiled on sailing performance . I have a Venture 24 that will out sail it I believe.ASk will to see my list of options and call me with any Questions . Kenny on Beautiful Lake Gaston
- Terry
Both black cars and white cars readily show road dirt one day after a wash, they are the most difficult colors to maintain despite how classy the black looks.In spite of this, it is popular for its looks, to some owners.
The only reason I went with the blue hull is because they look so pretty and I enjoy dressing her up with pacific blue accessories!
Re: Buying a new Mac
[quote="Pete"]I am ordering a Mac from Scotts Yachts here in wilmington and wanted to open a discussion about options.
The basic options I think I will go with are
26M blue with trailer (I will be keeping the boat on the trailer)
Jib
Cruising Spinnaker
Sunshade
Swim ladder
All lines led aft
The swim ladder can be an important safety issue. - If you, or a guest, falls overboard, or goes overboard to inspect something, it's difficult to get back into the boat over the high freeboard without the ladder. (I'm assuming that he or she isn't unconscious at the time, which is another matter.)
Jib
Cruising Spinnaker
Sunshade
Swim ladder
All lines led aft
Pete,
My choice today is the same as it was in 2003 when I bought my M. The Tohatsu (Nissan) 90HP TLDI at 315#. It's a 2-stroke but improved technology. Mine cruises at 19mph at 4000-4200RPM and is miserly on fuel consumption at that speed. WOT 24-25MPH at 5400RPM.
There are a lot of folks that have 50's that are not satisfied with the motoring performance side of the boat. But no one that I know of that has gone with the large motors are dissatisfied with their sailing or motoring performance either one.
Kind Regards,
JonBill
Kind Regards,
JonBill
- pokerrick1
- Sailboat: Venture 23
- pokerrick1
Genoa on a furhler best
Russ;RussMT wrote:I'm debating buying the 150 gennie vs. the standard jib.
Can this be reefed down with the furling system?
Is it too much sail in heavy wind?
I highly recommend the Genoa ON A FUHRLER. Do not get the sunbrella cover - - - not cost effective. That way you get two sails in one. For lighter winds, let the Genny full out. For higher winds you can adjust the Genny to ANY SIZE JIB you need. Sometimes I bring out the Genny about 50% and get 2 MPH extra speed - - - but usually it's out 70 to 75%. I only have the genny full out when I am on a run going pretty much in a straight line for some distance. When I am in a tacking situation, the genoa is only out to the mast to make singlehanded tacking easier.
Rick
- Bawgy
140179144264 is the item # on Ebay for COMboat . His products are great
http://motors.search.ebay.com/_W0QQsassZcomboat
- ALX357
Each to his own preference .... having only a single fuel line and an easy concentric push-on connector at the tanks, seems easiest and most intuitive to me. (With a spare fuel line nearby)
I have four tanks of six gallons each, and each with the same kind of connector. I would not want to have to keep track of a four-way valve, or two two-way valves in series, to manage a simple task of feeding fuel to the motor. I would not want the clutter of so many fuel lines on the cockpit floor, and / or on the motor deck. It only takes a couple of seconds to unplug one fuel line from a tank and plug it into another tank. No need to open the helm seat, or reach down around the motor.
I think a tank-switching valve or valves and the added fuel lines would be an unwelcome and unnecessary complication.
While the workmanship of the woodwork is impressive, that deckwork appears to be prone to catch debris, and retain dirt around that area of the motor deck. But then, it appears to be easily lifted or removed for cleaning and access when needed.
