For now......... we will have to settle on, agreeing to disagree..
I might Make Time to attend to my pin pimples this summer. IF I DO ? I will photo and post what I find.. I have a electric plane... the proper way to remove gel coat and I might??? Use it on a small area to prove someones point.. what will be will be.. BTW if you have broken the hard surface of the epoxy on you hull you may well have now caused yourself more issues than you were trying to fix..
Over 10,000 of these boats and we see pin head issues not US quarter coin size let alone coffee can size..issues. We have seen zero fiberglass deterioration..
I have not worked on many fiberglass boats over the years.. But I have worked on a few.. Its those older boats that By and Large develop real issues.. Issues with fiberglass deterioration once violated.. What I do know for a fact, is, after having worked on numerous ones is ....Corvettes!
The Chemical make up of the fiberglass ( epoxy) bodies changed Drastically sometime between 1958 and 1972.. and again sometime between 1972 and 2003.. This last change.... was HUGE!
All The Old issues are now Gone...did the boating Industry follow Chevrolet or was it Chevy following their lead.. No matter Factory Fiberglass no longer has the issues with decomposition and delamination it once did..
I believe you said you used epoxy primer? Good choice.. Did you prep it properly?
I thought I did ...."Her" 1970 MGB.. The Car was ready do go and just one more prep an a wipe down with Dupont Prep Sol.. and shoot her .. My wife is a keeper for sure... among other things she does on her own.... is she'll cruise through my work shop regularly and pick up any and all the rags.. She washes them drys them folds them and returns them to the shop.. BUT to my surprise
She uses a laundry detergent that has fabric softener already in it.. 99.999% of the time that would be fine it would be wonderful.. Not for paint prep!!!
I ..Drain the water separator and change out the filter on the compressor Fill the pot and shoot paint.. SH_T!!
Whats wrong? Dang! Try another panel.. try ANOTHER panel.. Heck its a total wreck... fog the whole dang car and see where this stops??
I called the Factory paint rep.. in the end it was those clean spotless rags.. Yes she uses a detergent that has Fabric Softener in it ... I might as well have spray the whole car will silicon spray .. Strip all the paint and start all over again.. How did he know Right away? Its a common mistake among DIY guys.. even those with some background in what they are doing.. If I was you I would be checking that epoxy primer real close for fish eyes ..It may be hard to do unless you DA'd the bottom after grinding...1 day 1 month 1 year.. if you have that issue brewing.. All the paint the entire job will Have To Be removed and Super.....cleaned and done again.. Live and learn and Ive done this paint thing a bunch...for money....Go Figure...
