smartcubic wrote: ↑Tue May 10, 2022 5:46 am
[quote=Jimmyt post_id=341961 time=<a href="tel:1588681782">1588681782</a> user_id=16979]
[quote=DownSouth post_id=341960 time=<a href="tel:1588654796">1588654796</a> user_id=17988]
rolled up and ready for bed.....
Very cool!
Thanks for the pic!
[/quote]
i'm newbie here. I saw your roller furling mainsail and thought it was an improvement over mine. I've seen the drawings of the brackets that connect the mast and roller furling mainsail you drew. My product is wired from the mast to the bent tube that connects to the boom. I tried talking to the builder of this product, but I don't live in the US so I can't get his help. I guess I'll have to look at your system and modify it myself. I want to know how the red parts of the picture are connected.
[/quote]
Thank you for posting this! Welcome to the forum!
Yep, you have a couple of problems there that need to be addressed. But, I think we should be able to get you going.
The front bracket is missing. I don't believe you can make it work the way it's rigged, due to the tension required in the center cable - which serves as the rotation axis for the furling drum. You could fabricate a bracket that mounted to the mast that might work ok, but it has to be better than what you currently have.
You may need to get the sail off the drum so you can photograph the drum and we can see if anything else is missing. But we'll cross that bridge when we get there.
There is a tensioning line inside of the boom that allows you to tension the cable. It has two blocks in the boom to give you a mechanical advantage when tensioning. Mine was not rigged properly when I got it, so I had to take the curved tube out of the back of the boom and correct it.
I'll post the pictures I have and we can start working through it.
