HEY HIGHLANDER!! Did you get your bottom fixed yet?
OMG ! I hope thats not a proposition
I known u r talking about my trl center bunk failure !
The hull repair is only 75% repaired due to early cold weather , next spring need to sand & prep for final finish coat then she,s go to go , the boat trl center bunk mod is all complete , but requires the boat off the trl to tighten up the installed U-Bolts that will prevent that really F@#%ing cheap unbelievable 3 wood screw original factory installation from ever happening again totally irresponsible that someone let that kinda crap go out the door like that 50# grocery carts r built 10,000 times stronger than that , what the hull were they thinking !
