I have a Claw that I wanted to stow on a roller. bought the BRM for ~ $80 in West Marine - I guess it's the same one. I also bought a URM the same day, and then compared them on the boat. It seemed to me that the BRM did a better job of holding the Claw away from the bow.Dimitri-2000X-Tampa wrote:Frank, is this the anchor roller you bought, the BRM-2?
I notice you said you originally bought it for a Bruce, if you had it to do all over again with the Bull in mind, would you install the same roller?
Would I choose BRM for the Bull? Not sure about that. I don't think one needs the BRM bulk out there to carry a Bulwagga, so the URM might be even better. The flukes are quite widely spaced, so it could stow closer to the bow without difficulty or risk. My boat is some distance away. I recommend that you measure from bow to anchor locker, go to West Marine with your tape measure, and pick the cheapest roller that will cover most of that bow distance, plus the BRM. One of those two will definitely carry a Bull adequately.
Installing a bow roller in a late model X is probably harder than the early models. This is because access is extremely limited. Remove the bowlight, dry-set the roller, test for anchor clearance, repeat, repeat, repeat, drill the deck holes, caulk and bolt it down, reinstall the bowlight (mine's still in a box). I also installed a backing plate that crosses from cleat-to-cleat, for the aft roller bolt. It's clearly a 2-person job, and took me a whole weekend, but maybe I was too picky.
The anchor roller is one of those deceptively magic mods. You know it should make life better, but you don't realize HOW MUCH BETTER, until that first time you're weighing 17# plus 15' of chain across that silky smooth roller.
Tying down the anchor? The Bull must be well-restrained for safety. If it ever fell from the bow under power, I can almost guarantee that it would grab. Your crew would fly forward as if you'd hit a wall, and no telling how much you might damage the bow, the pulpit and the cleats. It's really that dangerous. If it hit the highway, people could die! Bungies are an unsightly choice, but I've not yet bothered to finish it off. I'll find some way to pin it to the roller, or install a chainstopper.
