Spray in cockpit while under power
sorcha
Post by sorcha »
Whenever I have my 26M under power and there is a significant cross wind there is a big issue with spray coming in the cockpit. Obviously it doesn't help that the steering position is right in the back of the boat (unlike most power boats).
Just a thought of a possible solution for this problem... Has anybody investigated or tried spray strakes on the hull to deflect the spray?? The water's nice and warm here (Australia) ... the real problem is the saltwater is getting in my beer!
Thanks guys for your help.
Terry
Post by Terry »
Do you have ballast in when the spray gets you? If so, emptying the ballast reduces the amount of spray entering the cockpit. If you still get spray with an empty ballast then you can justify a wide dodger that goes outside the winches for protection. That is how I am explaining it to my wife so that she does not get wet. :wink:
Post by Frank C »
Yes. I believe it was Tony D who added spray strakes to his 26X, some years ago. I've always been a bit leery of that solution though. Seems to me that strake will act as a mini-keel when heeled under sail.
It might help redirect the hull to prevent a round-up (the good news) but it's curving shape would surely add a prodigious amount of drag, wouldn't it??? :|
Search on smart rail, and click 'all terms'
P.S. Terry's above comment is 100% correct. When ballasted, the Macs plow through the waves and create vast sheets of spray ... and when unballasted, they tend to climb over the waves, producing much less spray. Even so, any upwind quarter-heading will direct spray directly at the helm. That's why Terry & Mate want that wide dodger ... and that's why they're absolutely correct!
40Toes
Location: St. John's, Newfoundland, Ontario 28 - Formerly 2000 26X
Post by 40Toes »
Not that I would advocate drinking and sailing, but I did encounter this problem several years ago as guest on a boat - basically a flap of duck tape to keep the spray out of the can and grow a moustache. As the water runs down your face it gets caught in the moustache and your beer remains salt free. If you are sailing in freshwater don't worry about it, just pretend you are drinking American beer! :)
bastonjock
Post by bastonjock »
if you dont want a full cockpit dodger,you could consider fitting canvas spray dodgers to the sides of your cockpit,they are quite a common sight here in the UK
Currie
Post by Currie »
Or just switch to Margaritas :wink:
Post by K9Kampers »
Don't fight it...just switch!
SEAWATER BEER :D :|
