Centerboard Pin
Posted: Wed May 28, 2008 12:59 pm
by Snow Goose
Does anyone know what material is in the centerboard pin? Mine is very pitted and I would like to replace it.
Thanks
Posted: Wed May 28, 2008 2:27 pm
by Don T
Hello,
Pitted? It should be made of stainless.
Posted: Wed May 28, 2008 5:16 pm
by LOUIS B HOLUB
I did a bottom job recently, and my pin is stainless. It was shiney, like new, & clean. I had to insert a 1/2" PVC (schedule 40) pipe through the Centerboard because it was rounded out somewhat. The Pin fits perfectly thru the PVC, and works well with this combination.
But, I thought all CB pins were stainless.
Posted: Wed May 28, 2008 6:40 pm
by Snow Goose
It looks like a stainless sheath on a steel pin? The stainless is worn in places, I assume from the movement of the centerboard?
Posted: Fri May 30, 2008 4:13 pm
by TrueNorth
LOUIS B HOLUB wrote:I did a bottom job recently, and my pin is stainless. It was shiney, like new, & clean. I had to insert a 1/2" PVC (schedule 40) pipe through the Centerboard because it was rounded out somewhat. The Pin fits perfectly thru the PVC, and works well with this combination.
Louis,
Can you explain how you inserted the 1/2" PVC pipe over your centerboard pin. How did you access pin and any problems during repair?
Thanks.
Posted: Sun Jun 01, 2008 9:17 pm
by opie
CB REPAIR
Here is a link to a comment I made in 2007, now in the archives. Pitting will not hurt anything, as you can see mine is pitted as well. The pin only touches the fulcrum holder in two small spots.
