rough seas
Posted: Mon Aug 18, 2008 2:36 am
it was a morning to live for as i set off to travel 90nm to my new mooring,there was a light breeze and the sunrise was straight out of heaven,the sun rose from behind some trees siloetting them(SP) against the red then orange of the rising sun as i sipped my morning starbucks,it felt great to be setting out,the smell of the sea beckond so off we went.The Forecast was for SE winds building to 20-25mph with 30+ later.The first 20nm was done with both sails up and the engine ticking over at 1000rpm,as i rounded the Norfolk coast line,my bows lined up with the wind so i had to dropy the sails and go on motor,the weather was not too bad and i had no real concerns as i had been out in rougher stuff with C130 king.
I attained my goal of Lowestoft,after stopping briefly to watch my son kite surfing,like any father i felt pride at watching my son wizz along.We left Lowestoft at 6am,the forecast was for a wind over tide situation,we wrapped up well against the elements,for the first 10nm it was not too bad,but the wind picked up and so did the seas,wave height was 3-4 ft with a close frequency so it was bumpy and wet,so wet that my chartplotter packed up,we headed on and came to an area called Orford Ness,synonomous with Nuclear experiments here in the UK,i had been glancing over the charts using my hand held gps but had failed to spot an area marked with "outfalls",well those waves went from 23-4 ft to something around 5-7ft with one that came through causing the boat to pitch at an angle in excess of 45 deg,it was a bit hairy,i quickly ran safety proceedures through my head,and not wanting to cause alarm i quietly gathered the flares and hand held vhf,if anything larger came through,i was worried about the rudders being able to take the pounding,we soldiered on and passed the real danger,i had been at the helm for about 1.5 hours and i was cold and thoroughly wet,i asked my crew to take a turn as it was back to the 3-4 ft wave height,i went below and stood just below in the companion way for about 15 mins,i had briefed the guy to look out for sandbanks and channel markers but the visibility had dropped to 1 mile and the radio was not picking up traffic very well,i popped out of the hatch and sat on the soggy seats,i had looked around earlier and saw no danger,thinking that the hemsman was capable of spotting a body of shingle jutting out of the sea was an error on my part,im the skipper.the buck stops here.I turned my head and saw the danger,i acessed the situation and ordered hard down on port hand,we fought the boat around and headed back wards,i took the helm as i could see the channel by way of wave disturbance, we motored on and i picked up the bouyage that i was looking for,the trip ended in smooth seas in sunshine,this countrys weather is crazy
i look forward to going out again,lessons learned,question your crew untill you are fully aware of their levels of experience,dont take their say so,check your charts thoroughly, and check them again,do a thorough passage planmcheck those charts and make sensible notes kept in a water tight see through wallet
