Mystery electrical cable on 2004 M26
Posted: Tue Sep 09, 2008 3:05 pm
I recently purchased a "bone stock" 2004 M from a private party, and decided to re-do the electrical system.
Everything has gone well, except that I can't figure out what one pair of cables is.
The wiring in question is inside the aft berth and seems to come from the rear of the boat, near the motor. It's a 12 gauge wire pair, that was wired to the 3 way batter switch. It is not the Rear Nav light, I already traced that one down, it's not the main leads from the motor, those cables are much larger, and I have Identified them already. The wire is the same type of wire used throughout the boat so I think it's original, just can't figure out what it's for. I don't see any "extra" lights or other equipment in the rear or in the cockpit that would use this feed. All the equipment on the steering column is powered by a different cable that I have already identified.
I have a Yamaha 60HP motor, would the extra wires be the Alternator feed? I though that power came down the motor's primary (big) cables.
Any help is appreciated, Thanks
Wes T.
Wes T.
