Can you put an x on a m trailer?
Posted: Wed Sep 10, 2008 2:12 pm
by Doctor Z
I have a chance to lend my 2005 26M trailer to a trailerless 26x owner. I know the hulls are shaped somewhat differently but enough at the key contact points to make a difference?
Re: Can you put an x on a m trailer?
Posted: Fri Sep 19, 2008 8:10 am
by Loala
I've only heard they are different.
I suspect the bunks would be positioned differently as the
has a deeper cut "V" and a possibly a wider aft on the
Did you find out anything?
Reason I ask is I have an
and was thinking about buying an aluminum
trailer and fitting the bunks to match my
TIA.
Posted: Sun Sep 21, 2008 9:14 pm
by Doctor Z
I still havent got my question answered - didn't get a private message either.
Has anybody done the bunks mods?????
Posted: Sun Sep 21, 2008 9:43 pm
by Hamin' X
With minimal time searching the archives, I came up with this post from the past.
Re: anyone adapted aluminum M trailer to the X? Perhaps you can shoot him an email for more info, or do some more searching?
Posted: Tue Feb 24, 2009 2:49 pm
by mikelinmon
Easy adaptation. Reduce the ( V ) in the back bunks. The amount of ( V ) is: 3" lower in the middle than a point 2' 6" out from thr middle. Remove the blocks at the middle of the trailer and bolt the boards up directly to the frame. ( V ) block in front is OK as is. Happy trails
MIke Inmon
