Need a fishtape
Posted: Sun Aug 23, 2009 4:54 am
by c130king
I am about to install my new electrical panel, dual batteries, VHF/DSC and Stereo & Speakers. I imagine I will need a fishtape to get the wires pulled through all the places that I need to pull wires through.
I have never seen a fishtape and of course never used one.
Does anyone have a recommendation of a fishtape that will be fit for purpose for these applications? Cost? Where to buy? Etc...
And tips on using one?
Re: Need a fishtape
Posted: Sun Aug 23, 2009 5:43 am
by craiglaforce
home depot or lowes electrical dept. Comes is a reel made of either plastic or steel about 10 inches in diameter.
I'm not good at it , so have no advice worth giving, except maybe to get one no longer than you need. I absolutely hate using them. they get sharp spots that can cut your hands, they are always twisting some way that is wrong, they are dirty, and really don't work well for me.
Re: Need a fishtape
Posted: Sun Aug 23, 2009 6:41 am
by Retcoastie
Jim,
An old tape measure with the hook cut off will work. A tape is not too hard to work with. Like most boat things it just takes a little practice.
:P
There was a thread awhile back about using two magnets to pull a sting across the overhead.
While you are pulling, I did, and would recommend that you, pull a nylon string thru first. Cut it at more than twice the length and anchor each end. Then, if you ever decide to pull a second wire you won't have to go thru those contortions again. :)
Re: Need a fishtape
Posted: Mon Aug 24, 2009 5:58 am
by Highlander
Mechanics wire get the thicker heavier stuff not the light stuff you can bend it , shape it , twist it , turn it as you feed it into where ever you are trying to reach ! when running wires up to the area above the mirror on the S/B side of the D/B trunk I ran extra wires while I was there
http://i235.photobucket.com/albums/ee20 ... 0002-3.jpg
same again above the S/B side aft berth entrance where the little round mirror was for access to the winch mount bolts I installed a another switch panel there also
http://i235.photobucket.com/albums/ee20 ... 0009-1.jpg
http://i235.photobucket.com/albums/ee20 ... 0008-3.jpg
http://i235.photobucket.com/albums/ee20 ... 010010.jpg
http://i235.photobucket.com/albums/ee20 ... 010027.jpg
on the P/S aft berth area where my 110v, main hydro panel is you can also see were I ran two extra 10g red/black wires up to the main 12v panel above for future use
http://i235.photobucket.com/albums/ee20 ... 010072.jpg
http://i235.photobucket.com/albums/ee20 ... 010073.jpg
Now the Pedestal have fun
http://i235.photobucket.com/albums/ee20 ... 010003.jpg
http://i235.photobucket.com/albums/ee20 ... 0013-1.jpg
http://i235.photobucket.com/albums/ee20 ... 010016.jpg
Hope this gives you some Idea's
Re: Need a fishtape
Posted: Mon Aug 24, 2009 1:31 pm
by Kelly Hanson East
Steel washer attached to the string of course. I spent 30 minutes trying to pull a stainless washer once
dumba***
Re: Need a fishtape
Posted: Mon Aug 24, 2009 5:30 pm
by Divecoz
Am I too late? I have been gone for a few days , dealing with Medical problems for ageing In-Laws......
There are basically 3 types of fish tapes. Blue Flat Metal Coiled steel.( if your ever on a plane going down over the ocean... you'll wish you had one of these.. Because the dang things always catch on something no matter where you use them :D ) There is a Brass Wound Sparky or Slinky tape both are really nice to work with , but very expensive to buy, and not good for long distance pushes. There are also Round Teflon tapes to be had , and they are non-conductive . We also use Fiberglass rods that screw together in 4 foot sections .
An old flexible fishing pole would work well IMHO and my Magnet and a String and Washer trick works well too.
What you'll need no matter your choice of tools ....patience :wink:
No matter what you fish through that space , drag along an extra string for later, as there will no doubt someday be, a later :(
Re: Need a fishtape
Posted: Mon Aug 24, 2009 6:27 pm
by Uncle Jim
I just finished up rewiring my X and had no luck with my electrical fish tape, I ended up using a four foot batten to get through the floation foam. I also gave up on the port side channels and routed all the wires through the channel for the hatch rails.
Re: Need a fishtape
Posted: Mon Aug 24, 2009 9:44 pm
by Divecoz
Uncle Jim wrote:I just finished up rewiring my X and had no luck with my electrical fish tape, I ended up using a four foot batten to get through the floation foam. I also gave up on the port side channels and routed all the wires through the channel for the hatch rails.
How large of an eye / end did you put on it?
Re: Need a fishtape
Posted: Mon Aug 24, 2009 11:45 pm
by c130king
I am buying a 25' fishtape from Home Depot (or my Dad is going to pick one up for me as I need it my first day back).
Klein Tools 25' Fish Tape
It is only $9.99 so no big investment lost if it turns out completely useless.
Thanks for all the tips on other techniques.
T-minus 5 days until I am back in Florida... 8)
Re: Need a fishtape
Posted: Tue Aug 25, 2009 1:17 am
by bastonjock
jim get an old wire coat hanger,straighten it out and use that,you will also need some PVC tape to tape he cables to the wire or fishtape,i pulled all of the cables in glissando using the above method.
florida in three days :D :) 8)
Re: Need a fishtape
Posted: Tue Aug 25, 2009 8:40 am
by Divecoz
c130king wrote:I am buying a 25' fishtape from Home Depot (or my Dad is going to pick one up for me as I need it my first day back).
Yep those new bullet ends are very handy and save a lot of time ... both with pushing and time spent making a proper end.
Re: Need a fishtape
Posted: Tue Aug 25, 2009 11:11 am
I can find Phish on CD, but not on tape anymore..
Re: Need a fishtape
Posted: Tue Aug 25, 2009 11:27 am
by kmclemore
Kelly Hanson East wrote:I can find Phish on CD, but not on tape anymore..
Silly boy.
THIS is a fishtape:
Re: Need a fishtape
Posted: Tue Aug 25, 2009 7:13 pm
by Uncle Jim
Divecoz wrote: How large of an eye / end did you put on it?
it had about a 1in bend to it. I was able to get it about 3/4 of the way form the port side channel (just forward of the galley) under the windows and lost it when it starded to make it up to the elect pannel to the port side of the hatchway. I was also attempting to pull it through with the existing wires but that didn't help at all.
Now that bullet shaped end might have done the trick, but then we get in to packing heat while onboard and this aint the backroom :P
