...Ran the cable down the arch and drilled a hole up under the hinge of the captain's seat. But that area seems to be full of foam...can't get the cable to go in. And I am having difficulty in getting a look or feel back up in there due to all the "stuff" in the way...
Although mine is an
, I had the same considerations for my antenna install. For the process of rewiring my boat, my
has a 2" hole, with finish plug, for access to the helm seat hinge. From here I carved out enough foam to reach under the stern light placement, then pulled the new wire thru while pulling the old wire out. I should have, but did not run the antenna cable thru here. I may use the new stern light wire to pull the antenna cable & a spare pull line thru to keep the antenna on the port stern rail.
Before doing that tho, I'll look at relocating the antenna to the starboard stern rail & running the cable thru the hole with the engine controls. Currently, my antenna cable runs along the outside of the cockpit & thru the companionway to the VHF. For final install, I'll use a
Blue Seas cable clam.
