Ah, they laughed and said man would never fly! I like the Windara solution. The issue is not whether the tank fills fast enough when you launch the boat or lack of stability at sea when the tank is empty. Now that I sail on inland waters, I often motor with the tank empty. It's the transition back to sailing mode that I'm addressing. Also, there is a lot of algae and other grunge around the dock, so it is preferable to fill the tank before entering the marina to prevent it from entering the tank.
As for the vent issue, I addressed that years ago by adding a 90 degree elbow to the vent hole under the step (I have a 96X) and leading a hose to a thru-hull high on the starboard side. It is high enough that there is no possibility of the tank emptying through it except in a knockdown. So an overfill condition would only force water overboard through the thru-hull. The LED tank full indicator covered in another post on the board would let me know when to close the clamshell.
The only problem a have with the under-hull solution is that I was planning to seal that hole permanently and increase the rear valve from 3 inches to 4, as with newer models. With the vent extension, I never go below to check the water level or open the other valve.
I'm looking for a solution to incorporate in the valve at the stern.
You naysayers might consider extending the vent hose to a position behind the pedestal. That way a squirt up the pantleg would indicate a full tank.
Just kidding!
Seriously, with the way I use the boat, I think it would be a good addition. When I sailed Tampa Bay and the Gulf of Mexico, I would not have considered it, so I know its not for everyone.
Bob
