Hi,
I had to take the dagger board out for inspection. I thought I rigged it back the same way, but it does not seem to work as well - It does not seem to drop down as well as it did before. It is a factory rigging on a 2009 mac M.
Could I kindly request description/pictures of how a factory mac26M daggerboard it rigged?
Kind Regards,
-- Amanul
Mac 26M factory daggerboard rigging
emailnomad66
- 1st Sail
Re: Mac 26M factory daggerboard rigging
check and lubricate the block . It may be a fit and wear issue. I would rote the board on its verticle axis to the current lead edge is not the trail. See if that helps with reduced friction when raising and lowering.
- Phil M
I agree. You probably installed it backwards, which is easy to do. The 'fat' side of the daggerboard faces forward.
http://www.macgregorsailors.com/modt/in ... ?view=1290
Phil M
Phil M
- Wrudd3
- Location: Slip at Mid Chesapeake Bay, 2005 M, Suzuki DF70A, "Island Time"
Phil,
Very nice job on the looks & performance on the daggerboard!
Will
Will
