I have searched the Forum for info on preferred configurations for the CDI Furler Forestay on the
1. Rigging singlehanded. Is there any easy way of getting sufficient tension into the forestay to allow the clevis pin to be slotted in, or is it fundamentally a two-person job? I had the mast raising system tightened right up AND the main halyard winched tight onto the pulpit, but I still couldn't tug hard enough with one hand to allow the other hand to pop the plug in. The rope loop trick would work fine while the boat is still on the trailer and I can stand off of the pulpit, but on the water it doesn't seem viable.
2. Turnbuckle connector. My forestay turnbuckle has the standard (fairly soft metal) saddle arrangement, which is secured with a clevis pin and a cotter / ring ding. This looks remarkably insubstantial, and I have temporarily replaced the flimsy clevis pin with a double-nutted s/s bolt (keeping the mast raising system and the main halyard connected to the pulpit just in case). Is there a better way? A horesehoe shackle maybe?
I'd be grateful for any guidance, thanks
