Tiller Extension for V17
Posted: Thu Sep 30, 2010 6:54 pm
My tiller has a hole for a tiller extension, but no extension. Can anyone recommend a vendor for the hardware to make the swivel or the entire extension? Thank you in advance,
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=16894
Thanks JoeV - but wouldn't it be easier anyway? If yer sitting on one side, to push it over to the other without having to get up...but then wait...you probably don't move the tiller around that much, the way you do in a little boat...right?JoeVacs wrote:those are used on little race boats so you can hike out and still control the rudder. Not much need on a keel boat. I think the hole is there to tie a line so it can be locked into position
I will have to disagree, Tiller extensions are used on boats of any size. The biggest reason you would need one is for racing so you can steer from the high side to reduce heeling or from the low side in traffic.JoeVacs wrote:those are used on little race boats so you can hike out and still control the rudder. Not much need on a keel boat. I think the hole is there to tie a line so it can be locked into position
... so , .... what are you disagreeing with ?grady wrote:I will have to disagree, Tiller extensions are used on boats of any size. The biggest reason you would need one is for racing so you can steer from the high side to reduce heeling or from the low side in traffic.JoeVacs wrote:those are used on little race boats so you can hike out and still control the rudder. Not much need on a keel boat. I think the hole is there to tie a line so it can be locked into position
The little race boat part and not much need on a keel boat. to me little race boats are 17ft or less. Tiller extensions are used on 30+ft race boats. I think they are very useful for visibility you can sit on the high or low side to look for traffic or sail trim. That post was nothing personal just posing a different view point.JoeVacs wrote:... so , .... what are you disagreeing with ?grady wrote:I will have to disagree, Tiller extensions are used on boats of any size. The biggest reason you would need one is for racing so you can steer from the high side to reduce heeling or from the low side in traffic.JoeVacs wrote:those are used on little race boats so you can hike out and still control the rudder. Not much need on a keel boat. I think the hole is there to tie a line so it can be locked into positionRacing... aint that what I said ? .... It's what I thought I said anyway
anyway, yeah ! I agree wid you man !
