Newbie Mac owner. Mistakes made and lessons learned.
Posted: Sat Oct 16, 2010 5:16 pm
Hi all ....
I thought I would start this thread as I have had just about zero sailing experience and thought my folly's might amuse the experienced captains and serve as a warning for the rest.
First of all a very big thanks to Darren (BrazDaz) who generously gave up part of his weekend to help the crew and my self with our very first sail on the swan river in Perth Western Australia.
Darren gave us lots of tips and provided a much needed security blanket for this "3 hour cruse" (insert gilligans island music here).
Cheers Darren very much appreciated.
We have been out twice in our boat so far.
The first time we just putted around the river getting used to it.
Mistakes made included.
MISTAKE 1. Read and re read ALL the manuals for your equipment.
Particularly your chart plotter manual if you have one. I thought I had it right ... but I missed a very important minus sign when setting up the keel offset. (I obviously need my prescription changed for my glasses, having said that it was microscopic even with a magnifying glass).
So ... you guessed it .. I put in a positive keel offset and not a negative one so I thought I had a lot more water under the boat than was actually there.
And ... you guessed again..... I hit a rock.
Thank god I had the centre board and rudders up that day and I only managed to bugger up a prop. (which fortunately still worked well enough to get us home).
MISTAKE 2. Do a full load (full amps) check on all your equipment with all lights radios TV microwave and washing machine etc on.
We took so long rigging it was dark by the time we found our first mooring for the night and when I went to plug in the spotlight it worked .... (for a while) ... then blew the main fuse to the switch panel. (I am actually an electrician so this is an even dumber mistake my me).
MISTAKE 3. Take 2 boat hooks. One is bound to fall over the side ..... edit: this is going to be our next boat hook. http://www.wrino.com/
One did .... and no spare.
We are going to tie a small line on the hook and clip it to the boat before attempting to pick up buoy mooring line. My wife finds it very difficult to do if she can't just drop the hook and put both hands on the buoy line. The line on the hook will just let her drop the boat hook without worrying about it.
Sailing and rigging tips from Darren were invaluable.
I think the best one was.
Leave every thing you can connected to every thing else that you possibly can when de rigging to enable you to do a quick rig.
I had pulled just about everything apart. Firstly just to check it all ... and to make it a bit neater when loading up the boat.
Neatness gets in the way of sailing time. So as ugly as it looks .. the mainsail is NOT going to be put in the sail bag every time. In fact it will probably never see the inside of that bag again.
Second trip out with Darren also included a couple of errors (on my part.)
Not really a mistake but prepare well ahead of time for your docking.
ie: centre board up, rudders up. (one down helps for manoeuvring (Darrens tip).
Rushing these at the last minute can distract you just at the wrong time.
Darren and myself are both pilots (me an ex one .. with only 100hours) .. and Darren reminded my of the old, 'Fly ahead of the plane" advice given to me as a student. It applies equally well to boats.
MISTAKE 4
The swim ladder leg will take a nice little chunk out of your starboard rudder if you don't have it fully up. (I wondered why the rudder had been repaired there before, previous owner had obviously made the same mistake.)
Unless the ladder is secured with the pin and not just hooked up with a rubber strap (like mine) the little leg that sits on the transom will bite the trailing edge.
Anyway .. we are all still alive .... and had a great day apart from my son getting a sore throat and fever. So sailing was cancelled early.
I will continue to add to this thread as more mistakes and tips for newbie's emerge.
Thanks again Darren,
Phill
MISTAKE 4
Phill
