SS - Aluminum galvanic corrosion points
- craiglaforce
Just wondering how much corrosion others are experiencing in areas where the Stainless steel is in contact with aluminum. I have noticed that the aluminum rudder head brackets are corroding quite a bit under the stainless steel pivot bolt and washers. Probably should put a teflon washer under there and maybe a sleeve for the bolt. I haven't noticed much corrosion on the mast yet, except maybe on the bottom where the aluminum mast rests directly on the stainless steel tabernacle hinge plate.
Here is a link to an interesting site about galvanic corrosion.
http://www.corrosion-doctors.org/Forms/FormType.htm
