Garhauer rigid vang mod
Posted: Sun Jan 16, 2011 10:38 am
by Highlander
I am going to remove the cleat from the bottom of the vang as it is a PITA to release & set from that possition more so when you have a dodger like me
http://i844.photobucket.com/albums/ab1/ ... 010155.jpg
http://i844.photobucket.com/albums/ab1/ ... 010154.jpg
& install an extra pulley $18. @ the boat show from Garhauer
Here's the set up they had on display at the boat show
http://i844.photobucket.com/albums/ab1/ ... 010004.jpg
http://i844.photobucket.com/albums/ab1/ ... 010003.jpg
Add a ss tang to the pulley as seen in this pic
http://i844.photobucket.com/albums/ab1/ ... 010002.jpg
and move the cleat back to poss beside my power clutches then I can easily adj. it
http://s844.photobucket.com/albums/ab1/ ... 010001.mp4
Re: Garhauer rigid vang mod
Posted: Sun Jan 16, 2011 6:45 pm
by ROAD Soldier
Since your whole mast moves on an
wouldn't that cause resistance to the mast pivoting?
Posted: Mon Jan 17, 2011 5:06 pm
by Highlander
ROAD Soldier wrote:Since your whole mast moves on an
I think I can work around that by running the proper pivot angles
but have to wait until spring to get the mast-up to work on that part of it
on an M if you mount your halyard base pulleys in front of the mast as I did it will not interfere with mast rotation
Posted: Mon Jan 17, 2011 5:13 pm
by ROAD Soldier
Be interesting what you come up with. You already gave me an idea for my
for running the regular block and tackle boom vang back to the cockpit.
I always hated balancing myself on the mess bench seat ledge with an open companionway hatch trying to pull down on the boom vang in rough seas.
Posted: Wed Feb 02, 2011 6:31 am
by streuber
I also purchased the Garhauer rigid vang mod from Kelly Hanson for my 2007 26M. I have had it on the boat for three years and it has served us well through many long trips. However, I have a question concerning a long spring that came with it. I do not see the spring installed in your rig either. I called, emailed and did everything but send smoke sigals to Kelly Hanson regarding this. No reply.
Since no documentation came with it, I am clueless as to where this spring goes. Any ideas?
Posted: Wed Feb 02, 2011 8:46 am
by Highlander
streuber
Please post pic's I have to asume you got a spare compression spring ! if so lucky you !
the rigid vang should be spring loaded with an internal spring inside the SS Tube section of the vang, you should be basicaly be able to swing off the end of your boom and the vang will suport your weight !
most of us anyway ?
If your vang is not spring loaded ! it will not be doing the job it is intended to do !
, just doing the same thing as a regular vang with some rigid support , when my rigid vang is unloaded it will raise the boom up nice and high outa the way
hope this helps J
