I looked over the Aurinco panels at the Annapolis boat show last October, and I am quite impressed. They are "ultra-thin" as advertised, and they're made so the wires don't have a protruding "strain relief" like the Sunwize SolCharger panels - another panel that's "step-on strong," or so I gather from the SolCharger brochure. But yes, they are pricey.
By my measurements on Bossa Nova, the 50-watt panel would fit very nicely on the cabin top ahead of the hatch slider, unless you're in the habit of sliding that hatch all the way open. (I'm not; I open it just enough to pull out the 'washboard,' and then keep it slid back. I regard that open hatch as a severe hazard, and an unnecessary one, when you're aboard the boat.) It would go edge-to-edge, almost, on the non-skid area forward of the hatch slider, and at 16" long, it would still let you slide the hatch open about 12" or so.
But 50 watts is not enough to run a fridge, is it? At the same time, it's way more than I'd need to keep up with my GPS. There's also the "all your eggs in one basket" problem of shadows on a big solar panel; even a band of shadow across a solar panel can cut down its output considerably. Might it be better to have more than one panel up there under the boom?
After thinking over my real power needs, I've ordered two 12-watt SolCharger panels from MrSolar.com - they cost me $130 each, plus shipping and MD sales tax. They may not run a fridge, but they'll keep my batteries topped-up and they'll keep up with my GPS power needs. I plan to install them up on the cabin top, just aft of the mast, and they won't take up much room at all (13" fore-aft, about 12" either side of the centerline, as I'll install them). I've figured how to use a short "C" section of PVC pipe (cut lengthwise) as a "riser" under the edge with the strain-relief box; it's the same thing I did to mount my (now cracked and non-functioning) Sunsei solar panel that I'd mounted on the hatch slider, as I posted in
http://www.macgregorsailors.com/modt/in ... ?view=1128. I will pull the wiring down through the cabin headliner, and I'm going to try and rig everything so a panel can be replaced if something catastrophic might befall it.
Actually, a real power-hog could mount
two more of those Aurinco panels on top of the hatch slider, for a total of 150 watts - that'd keep up with your Engel fridge and your DVD player! But at $550 per panel, $1650 total, I'd rather buy that Wallas stove like Chinook's....
