HI Paul,
A few more bits of good info:
Good Articles on Boat Trailers
"Bow2Stern- the passion for boating in Qld"
http://www.bow2stern.com.au - series of 6 articles on trailers from Issue 3 (Nov 2008) to Issue 8 (Feb 2010)
Issue 3 (Nov 2008) - Aust Desing Rules (ADR), Vehicle Standards Bulletin (VSB1), Lights/wiring, Brakes, Drawbars & Couplings, Wheels & Tyres
Issue 4 ((Feb 2009) - Different types of boat support systems on trailers
Issue 5 (May 2009) - Trailer safety/maintenance check issues
Issue 6 (Aug 2009) - Galvanising
Issue 7 (Nov 2009) - Suspensions
Issue 8 (Feb 2010) - Safety - sway, towball weight, windage, brake controller, driver experience
Plus
These are VIN plate definitions of the Caravaning Aust web site although I can't get the link to work:
http://www.caravanqld.com.au/media/9824 ... itions.pdf
A.T.M. (Aggregate Trailer Mass)
This is the weight on all the wheels, plus the ball weight, plus your personal load, including water, gas and
any accessories you fit. The total of all of these weights is the Aggregate Trailer Mass (A.T.M.)
G.T.M. (Gross Trailer Mass)
This is the weight on all the wheels, plus your personal load, plus water, gas and any accessories you fit.
The total of these weights is the Gross Trailer Mass (G.T.M.)
TARE (Tare Mass)
This is the weight on all the wheels, plus the ball weight. The total of these weights is the TARE. The TARE
does not include water and gas as these items form part of your personal payload.
PERSONAL LOAD
Personal load means the weight of all items added to your trailer or caravan such as - clothes, food,
hoses, crockery, cutlery, tools, water, gas and any accessories you fit (ie. TV set, radio, awning, push
bike, additional spare wheels etc.). The total weight of all items added to your caravan or trailer is the
Personal Load.
WARNING You must never exceed the GTM (Gross Trailer Mass).
To do so could overload the suspension, chassis or frame and thereby cause an accident by component
failure.
If in doubt about the weight of your caravan or trailer you should weigh it when fully loaded on the road
including full water tank(s) and gas cylinder(s). This can be done at a Public Weighbridge (check Yellow
Pages for locations).
HOW TO CALCULATE WHAT PERSONAL LOAD YOU CAN CARRY IN YOUR TRAILER OR CARAVAN
To calculate the maximum load you can safety carry in your trailer or caravan, take the TARE (as stamped
on the trailer plate), from the aggregate trailer mass. A.T.M. (as stamped on the trailer plate). The A.T.M.
minus the TARE equals the maximum load your trailer or caravan can carry.
Information from the Recreational Vehicle Manufacturers Association of Australia in the interests of
customer safety.
