I have a stainless steel "hook" at the aft and near the mast end of the boom. I assumed they were for the reef cringles.... but they don't fit my mainsail.
There are also blocks on the mast that I guess are for a single line reefing of the main. Can anyone help me with this?
I am asking this because I would enjoy easy reefing when I am single handing AND I am about to try implementing and "easy flaking" mainsail idea. Flaking is a poor word choice. I have an idea to lessen the bungee mainsail tie down drama.
I'll attempt to paint a word picture and would appreciate comments.
I plan to anchor a bungee cord line to a spot on the side of the boom near the mast, about 2 feet aft on the boom, probably another anchor point (possibly loop the bungie around a post with a oversized washer head, then aft to a point probably around 3/4 the way aft to a final anchor point.
The other side of the boom would have a bungee diameter sized spacer and oversized washer bolted to it at spacing that will place it between the anchor points on the other side.
Operation should be simple. Once the sail is flaked on the boom, you reach over, grab the bungee and pull it over the top slipping it under the standoff spacer on the boom. Step forward (or aft) and repeat.
The bungee is protected from weather by the sail cover.
Could also serve to shoot clothes pins at the Windex if necessary.
Any holes in my logic?
