How straight is your mast?
Posted: Fri May 11, 2012 3:51 pm
by Bluecrab
After setting the rake and adjusting the shrouds I sighted up the mast and it appeared to be bending to port. Adjusting the shrouds I seemed to have gotten most of the bend out but the mast track still appears to be wavy.
Should I be able to get this better or is this just the way these masts are?
Wally
Re: How straight is your mast?
Posted: Fri May 11, 2012 6:50 pm
by Mac26Mpaul
When I got my boat the rotating mast used to bind up on one side. Eventually I realized that the main problem was my mast not being setup properly and she was bending to port. I spent a morning on it. Loosened all the shrouds off to the point where none were tight, and then climbed up and down off the boat for the rest of the morning slowly adjusting them. I'm not sure if this is the smartest way to do it, but eventually I got it nice and straight and the mast no longer binds up. You need to do some more playing to get it straight... Looks like your close, maybe a notch tighter port lower, or starboard upper, or both.........
Posted: Fri May 11, 2012 10:05 pm
by Bluecrab
Mine has been binding also. When the sail was down or when raising the mast it had a tendency to swing to starboard.
After these latest adjustments it behaves much better. Really worth the effort.
Wally
Posted: Sat May 12, 2012 12:46 am
by Mac26Mpaul
For sure Wally,, , once my mast went to port, it didnt move, no matter how strong the wind was. As I said, I got it straight, and I also, took the base off and greased the two washers up - No more binding at all, and the mast moves as it should in all but the lightest of winds.
Deffinately worth the effort to get the mast straight! :)
Posted: Sat May 12, 2012 4:50 am
It should be straighter than the pic....check tension on shrouds. Make sure the thimbles aren't cocked on the mast tangs.
Posted: Sat May 12, 2012 12:05 pm
by bscott
Check your spreader height then retension your shrouds.
Bob
Posted: Sun May 13, 2012 7:32 pm
by Bluecrab
bscott wrote:Check your spreader height then retension your shrouds.
Bob
Good call Bob, the dimension from the top attachment point to the center of the spreader is supposed to be 12'. One side was off buy 3 inches.
I replaced the upper shrouds last year. They were nicked up from binding on the adjusters when raising the mast until I installed plastic tubes.
While not perfect, the one on the right is after fixing the spreader height and working on it all Saturday afternoon.
Wally
Posted: Sun May 13, 2012 8:27 pm
by vizwhiz
Wow...is your mast supposed to be that fat at the bottom, that pointy at the top, and that short?? :o :o
Posted: Sun May 13, 2012 11:31 pm
by Wind Chime
by Bluecrab » Sun May 13, 2012 7:32 pm
Should this 12' distance be the same on a model "X" as well?
Posted: Mon May 14, 2012 7:47 am
by bscott
I have a :macm: mast so I can't comment on the :macx: but I use a T square to set my spreaders which seem to need adjustment from time to time. Hope this helps,
Bob
Posted: Mon May 14, 2012 8:16 am
by kmclemore
Man, I gotta tell ya, given the title, it's a good thing this is a sailing forum.
:wink:
Posted: Mon May 14, 2012 9:11 pm
by Gater Dunn
kmclemore wrote:Man, I gotta tell ya, given the title, it's a good thing this is a sailing forum.
:wink:
why is it that the moderators come up with all the potty talk :?: :P
Posted: Tue May 15, 2012 3:22 am
by MacTommy
:wink:
Remember, the mast of the :macm: 's are taller...
:D
Posted: Tue May 15, 2012 4:02 am
But thy are always blue......
