How does this look?
PlanetExpress
How does this look?
Post by PlanetExpress »
Hey Guys,
Can you take a look at these pictures and make some suggestions to improve the performance. I had to take them at night, sorry they are a bit hard to see.
Aaron
PlanetExpress
Re: How does this look?
PlanetExpress
prishi
Post by prishi »
Looks good. As in, just like mine..... almost, but hard to commend on performance with pics alone....
prishi
Post by prishi »
Unquote
Mabe a better camera and a bigger flash?
:wink:
RobertB
Post by RobertB »
How about a bit more information on what you are tying to improve? I assume you are not looking for advice on what fabic colors go with brushed alumium, stainless steel, and white fiberglass :) (although the blue line in inself will make the boat sail faster 8)
PlanetExpress
Sorry, I meant to add this to my last post.
I should have explained better.
Pictures 1 and 2:
Do they look to be at the right angle? I know its impossible to tell but I don't think they are tight enough.
Pictures 3,4 and 5
Is that set in the right spot? Should I have the halyard pulled up more, down more? Did I put the pin in the right hole?
Pictures 6, 7 and 8
The shoe isn't flat to the deck, it may be hard to see but there is about a 1/4"ish space there. Is that right? I cant seem to get the darn thing to come down any further.
Sorry for the vague 1st post.
jbousquin
Location: Sacramento, CA 2011 MacGregor 26M 60HP ETEC "The Nauti Neighbor"
Post by jbousquin »
PlanetExpress wrote:Pictures 3,4 and 5
Looks fine to me. I'd put a new ring ding on, and I tape all my ring dings with black electrical tape to keep them from working free.
Pictures 6, 7 and 8
Foot of the mast will be brought down closer to the deck by tightening your lower shrouds. You can tighten your forestay, if you feel it's too loose, by tightening your uppers. Good luck.
Sumner
Post by Sumner »
I'd put a toggle on the bottom and top of the forestay if that is a CDI furler and probably any other also, but CDI wants them installed,
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
