woody addition
Posted: Mon Sep 17, 2012 11:59 pm
by Highlander
Well got me some laminated flooring 32$ a box on clearance for 15$ @ Lowes "Carribean Cherry" had bought 1 box last yr for my overhead cabinets which I have still to finish anyway decide to dress up some other mods I done
From this little shelf cut
http://i844.photobucket.com/albums/ab1/ ... 010018.jpg
to this
http://i844.photobucket.com/albums/ab1/ ... G_0982.jpg
from this plain bukhead
http://i844.photobucket.com/albums/ab1/ ... 010006.jpg
to this
http://i844.photobucket.com/albums/ab1/ ... G_0978.jpg
http://i844.photobucket.com/albums/ab1/ ... G_0981.jpg
so now contemplating making window frames duct taped this used cut out piece on the window to just see how it would look so this will be next
http://i844.photobucket.com/albums/ab1/ ... G_0939.jpg
http://i844.photobucket.com/albums/ab1/ ... G_0937.jpg
Re: woody addition
Posted: Tue Sep 18, 2012 1:39 am
by FinallySailing
Brilliant idea and very well executed ! Did you use the same laminate for the flooring in your cabin ? BTW, very much like the Scottish touch (I am married to a French Scottish Canadian and have lived until very recently in the west of Scotland
Re: woody addition
Posted: Tue Sep 18, 2012 7:10 pm
by Highlander
FinallySailing wrote:Brilliant idea and very well executed ! Did you use the same laminate for the flooring in your cabin ? BTW, very much like the Scottish touch (I am married to a French Scottish Canadian and have lived until very recently in the west of Scotland
No I am debating on whether to use it on the cabin sole as when it gets wet it can be very slippery
on the feet I will post the window frames when I get them done . "I am married to a French Scottish Canadian " well been with French , Scottish , Canadian & French Canadian women but not all @ once
" not saying I could not handle them all "
was just back home before Xmas to see family
Re: woody addition
Posted: Tue Sep 18, 2012 7:31 pm
by Divecoz
For Cabin Sole::There is a stipple effect that can be added to most surfaces that makes them slip resistant.. It might also help with sealing the cut edges ? What do the instructions say about suitable installation areas? Most I have checked into suggest: Not for Use In Kitchens or Baths or Anyplace dampness or water spill's may occure..
From another angle? Increasing your permanent ballast
... While I was looking for tile for the new house , my brother and I spotted 6" x 24" Porcelain tile , that properly installed ? Really has a remarkable resemblance to Plank Wood.. He has or will be shipping in or around 1500 sq ft of it to St Croix for a Home Remodel.. tehehehe
Re: woody addition
Posted: Tue Sep 18, 2012 9:22 pm
by yukonbob
Just removed my 3/4 ash hardwood floor from the cabin as it has soaked up up enough moisture to expand 5/8"
. Looked good and was cheap, but the expansion (very little moisture under boards, maybe just in air?) has started to scuff fg around cabin sole. So no replacing. Considering dri deck stuff or something similar but grippier. The laminate may last as long as the wood but most likely less. It does look good, but at the same time I don't want to spen time replacing it every other year...its just one more thing to do. Ah well.
Re: woody addition
Posted: Wed Sep 19, 2012 5:24 am
by FinallySailing
Re: woody addition
Posted: Wed Sep 19, 2012 7:41 am
by RobertB
I have been very pleased with the Lonseal flooring
http://search.defender.com/?expression=lonseal. It looks very good, has a good texture, is non slip when wet, is durable, and easy to clean. Installation consists of making patterns to cut the flooring, holding in place with carpet tape, and sealing the edges with silicone sealant.
Re: woody addition
Posted: Wed Sep 19, 2012 9:31 am
by Divecoz
Very Cool and do-able .. How many linear feet did you end up buying?
RobertB wrote:I have been very pleased with the Lonseal flooring
http://search.defender.com/?expression=lonseal. It looks very good, has a good twxture, is non slip when wet, is durable, and easy to clean. Installation consosts of making patterns to cut the flooring, holding in place with carpet tape, and sealing the edges with silicone sealant.
Re: woody addition
Posted: Wed Sep 19, 2012 10:29 am
by RobertB
I forget how many feet I bought but the sheet was wide enough I bought enough to cover the longest piece and could cut out all three from the width (I also installed under the table on my
) . BTW, Defender shipped some extra on my order.
Re: woody addition
Posted: Wed Sep 19, 2012 2:17 pm
by Scottie
Highlander,
Did you need to stain the edges? Were you able to match the color?
Scottie
