Rudder rope?
Posted: Sat Apr 06, 2013 2:11 pm
by dlandersson
I want to replace the rudder ropes (rudders two btw) on my
before launching it. Looks like 1/4" or 3/8"? How long should a
rudder rope be?
Re: Rudder rope?
Posted: Sat Apr 06, 2013 4:39 pm
by SeaGriff
Use 3/8 bungee cord, 12ft for each rudder. It works much
better than rope.
Re: Rudder rope?
Posted: Sat Apr 06, 2013 4:53 pm
by dlandersson
Link? There are many qualities of bungee cord.
SeaGriff wrote:Use 3/8 bungee cord, 12ft for each rudder. It works much
better than rope.
Re: Rudder rope?
Posted: Sat Apr 06, 2013 5:17 pm
by MAC-A-TAC
I replaced the rudder lines on my M, but I don't remember the length. You could tape a smaller diameter line to the existing rudder line and pull out the old line and measure it, then the thin line could be used to pull new line through the rudder hole.
Good luck.
God > Family > Country
Mac Out.
Re: Rudder rope?
Posted: Sat Apr 06, 2013 8:45 pm
by SeaGriff
I just picked up 3/8 bungee cord from my local Ag supply. They sell it
for secureing tarps. Works good I don't have a Link for it.
Re: Rudder rope?
Posted: Sat Apr 06, 2013 9:53 pm
by canmac27
Why is bungee chord a better option than rope for the rudders?
Thx
Re: Rudder rope?
Posted: Sun Apr 07, 2013 1:18 am
by Ormonddude
canmac27 wrote:Why is bungee chord a better option than rope for the rudders?
Thx
Lets the rudder kick up if you hit ground the rudder will be held to the tension of the bungee hopefully saving your rudder.
Re: Rudder rope?
Posted: Sun Apr 07, 2013 6:11 am
by Tomfoolery
Ormonddude wrote:canmac27 wrote:Why is bungee chord a better option than rope for the rudders?
That's an interesting idea. Mine has two separate lines to each rudder, and I certainly could use a bungee for the hold-down line, maybe with a loop at the right length to tension the bungee to hold the rudder down and a stopper knot for when it's released.
Or spliced (some how) end to end with the 'raise' line, so it's just one loop. I don't know how I'd splice bungee to braid, though.
Re: Rudder rope?
Posted: Sun Apr 07, 2013 6:36 am
by capncarp
I like the idea. But, how far does it stretch when you pull up a water filled rudder? Depending on how tight you have the rudders shimmed, they can get pretty heavy. I assume you just route it the same as Mac sets it up using stopper knots at the rudders. Any pic's?
capncarp
99
Re: Rudder rope?
Posted: Sun Apr 07, 2013 7:20 am
by raycarlson
search on rudder kick-up mod. we've been doing this one for years.you only use bungee on the pull down=hold down side, the lift up rope stays normal.
Re: Rudder rope?
Posted: Sun Apr 07, 2013 3:03 pm
by reastmure
raycarlson wrote:search on rudder kick-up mod. we've been doing this one for years.you only use bungee on the pull down=hold down side, the lift up rope stays normal.
I did a search on rudder kick-up mod but no results came up either in the mod section or forum??
Re: Rudder rope?
Posted: Sun Apr 07, 2013 6:04 pm
by csm
West Marinw asmteel or equal dynaneen rope for both center board and rudders. Snap lock cleats for the rudders are great; they POP when rudder hits ground, releasing/saving the rudder and giving an audible shallow water alert.
Re: Rudder rope?
Posted: Sun Apr 07, 2013 7:07 pm
by dlandersson
Cool = just ordered Amsteel in 1/4" black.
Length is 10-12 feet btw.
csm wrote:West Marinw asmteel or equal dynaneen rope for both center board and rudders. Snap lock cleats for the rudders are great; they POP when rudder hits ground, releasing/saving the rudder and giving an audible shallow water alert.
Re: Rudder rope?
Posted: Wed Apr 10, 2013 9:29 pm
by acmaui
I used 5/16" and added a pair of blocks to make it a lot easier to raise them.
