spinnaker and genoa sheets.
Posted: Sun Jun 23, 2013 2:22 pm
Hello all,
Next time I am out I will be trying to lunch my spinnaker for the first time.
I have a few questions - mostly to do with what to do with the Genoa parts when using the spin.
So firstly the head - I will be using the jib halyard to raise the spinnaker. It looks as though it will end up being just below where the forestry/fuller will be attached.
Usually the spinnaker is flown on "top" but I don't think I will be able to. now, assuming that is okay ( is it?) what happens to the genoa sheets? when I fuller the genoa, the sheet roll up in to the center of the sail, but they in in the middle of the air where they spinnaker would fly and tack back and forth. does this make sense?
Okay next issue - the tack --- I was going to attach it to the plate near the furler- with about 2 feet of line. I am not in NEED of an adjustable line, unless you folks say I need this.
lastly the clew - I was wanting to run it back around the rail, but the rail is not that tough. so what should I use- the genoa track already has the genoa block on it, and is being used for the fuller, and genoa -- I don't know if I have an extra set of blocks for the jib, do they fit on the same track?
thanks for the guidance. Kevin.
